Vanquish handbrake handle - fits DB7 V
Old Oct 16, 2022 | 02:21 AM
pld118's Avatar
pld118 is infamous around these parts
Aluminium AM handbrake handle - DB9 DB7 Vanquish
Sourced new, unused, made for AM aluminium handle, hoping it would fit my DB7 Vantage. It fits and cost a lot less than prices quoted online by AM parts suppliers.
The original black DB7V handbrake lever handle came off easily, with a pair of surgical gloves on the hands for grip. A few carefully forceful twists, pulls and off it came (the original DB7V handle is basically rubberised plastic). It’s not glued on, literally secured via the tightness of fit.
The aluminium handbrake handle fitted nicely on to the handbrake lever using similar controlled strength to twist and push it on, although I used a very light slither of moly grease to help get it on. Certainly no adhesive required, to fit either the original or the Aluminium handles - it’ll never come unless forced off.
The aluminium handle fits and looks really good. There is is a slight gap (approx. 3 cm) between the end of the leather handbrake lever sleeve and the start of the AM handbrake handle. The gap is no big unsightly issue though, as you can see on my attached images.
However, in pursuit of perfection, if you want a solution for what is a 3cm gap between the end of the leather handbrake sleeve and the start of the Aluminium handle… your local specialist auto trimmer tell you to stick a piece of matching leather colour to the handbrake lever to make it look “factory” no problem and for not a lot of cost at all.
Very pleased with this high quality AM upgrade 👍. If anyone is interested, might be able to source you one.
Old Oct 16, 2022 | 08:20 AM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Nice find…sweeet upgrade..
Old Oct 17, 2022 | 01:40 PM
pld118's Avatar
Thanks 👍
Old Oct 29, 2022 | 02:25 AM
pld118's Avatar
Also got another of these fine handles that was intended as a spare but, in hindsight, would probably not get used and so… someone else can hopefully enjoy it 👍
WG_moots
Dec 28, 2025 02:33 PM
AdamTaylorFsu
Jan 11, 2021 07:19 AM
plastique999
Jan 24, 2020 12:25 AM
deckman
Jul 18, 2017 07:35 AM
scottblack
Feb 17, 2013 05:30 AM
