Can anyone tell me if the '19 Vantages have the launch control function? I've watched a few videos on guys explaining how to do it with a '20 and it seems easy enough. When I try it in my '19, it doesn't work. Is this something that was added later? If so, shouldn't it be added if the car gets software updates?
I'm pretty sure this is their first car with Launch Mode. Compared to other cars in this class, the launch is ridiculously weak, but at least it has something. When I tried to launch mine, I had the suspension set in Track. I'll try it again with it in Sport. I also just bought my car from a local AM dealer. When I started it for the first time, I had an" Oil Over Full" code. Seeing that Launch Mode won't work if there are any stored codes, this could be another issue. I have an appointment to deal with the Oil code, so I'll see what happens after.
this should help with the oil issue.. R/R sensor... SEE ATTACHMENTS
The car is still under warranty as I just bought it, and it has the Timeless warranty, so I'm going to let the dealer deal with it. I had a Porsche that did the same thing and they had to replace the sensor. With this car, the previous owner never drove it. It only had 2000 miles when I bought it last week. Either way, after driving it last weekend, I've not had that code pop up, but the code still needs to be cleared.
Yup, its a glazed sensor from sitting... the heated oil from driving it cleared the "ultrasonic" signal... Change the oil first..IMO..
