Anyone using an oil drain valve?
Old Nov 23, 2022 | 10:22 AM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
I always change my own engine oil in my '06 DB9 and consequently have done it many times, but sometimes an oil change doesn't correspond with a need to remove the front undertray for any other reason. I will confess that I have, once or twice, drained the oil through the access hole without removing the shield and I've been reasonably successful in avoiding a mess. But I know that I'm risking it, and many owners on the forums have talked about getting their car back after a service and finding oil on the tray.
I'm thinking of installing an oil drain valve to replace the OEM plug with my next change. I've looked at examples by EZ, Fumoto, and ValvoMax online, and I'm particularly interested in the ValvoMax product. Of course, I want to ensure that it doesn't pose an impact risk and that the valve lock is secure. I also want to make sure I can open and close it easily through the hole in the tray, and that I can push a short drain tube onto the outlet when I'm doing a change.
Has anyone installed an oil drain valve in a 12-cylinder AM, and if so, what is your experience? Thanks!
Old Nov 23, 2022 | 02:04 PM
MAUMAU's Avatar
MAUMAU is infamous around these parts
I do not have an oil drain valve on the Vantage, but had an FAA approved one on my aircraft.
If they can stay closed on an aircraft where the the failure of said device could truly ruin your day, I think having one or more on your DB9 could work. They hang down a bit however, so you would have to measure each drainage point and see if it interferes with anything. You may consider using an anti-seize lubricant so that you will have less of an issue if you decide to remove the valve in the future.
If you move forward with this, please report back with pictures.
Old Nov 24, 2022 | 04:04 AM
MRCW's Avatar
Not sure I understand why... I've seen these on high use vehicles like OTR trucks and construction equipment... high volume high use
Removing the undertray during a service is a great way to just visually look at any other potential issues that could be going on.
Also most plugs are magnetized to collect any potential metal engine particulates,etc.
Seems like a 'fix' for a non-problem.
Old Nov 24, 2022 | 09:29 AM
zuman's Avatar
All good points. However:
  • The OEM drain plug is not magnetic
  • As I implied, I may have had the shield off for something else not long before or will be taking it off soon after.
  • As I only change oil once a year and don't have a lift, it's a challenge for me to get the plug unscrewed without at least some oil going where I don't want it to (up my arm, for example...).
  • I may be able to drain it while it's hotter with a valve.
  • Being able to direct waste oil into a pan via a hose might be useful.
  • I've spent $40 on far more useless things in the past.
So, I'm sure it's a non-issue for many, but I'm still interested in whether anyone has used a specific product, and if so, what they like or don't like.
Old Nov 24, 2022 | 10:55 AM
mrtzmd's Avatar
mrtzmd is infamous around these parts
I'd say go for it. Changing the oil on my vantage is easy but on a db9 is much more laborious. Anything you can do to make your maintenance less of a hassle while not impacting safety or performance is perfectly acceptable imho.
Old Nov 28, 2022 | 10:24 AM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
One issue to consider is the possibility of shearing it off if you hit something. Especially if it protrudes somewhat lower than the tray. I very much want to do the same thing.
Old Nov 28, 2022 | 02:58 PM
zuman's Avatar
I ended up buying a ValvoMax drain valve. I'm reasonably sure that it'll be recessed above the drain hole in the undertray as the entire valve, including screw-on cap and cap tether mount, protrudes just about 1-3/16" below the oil pan, but I won't know for certain until I get the car up on my QuickJack ramps.
I hope to change my oil before the New Year and I'll report back with photos. I really like how the ValvoMax isn't operated by a lever, but by screwing on the supplied drain hose, which opens the valve. That feature, together with the "fail-safe" screw cap, is pretty confidence-inspiring. It appears to be very well made (in the USA).
Old Nov 28, 2022 | 03:15 PM
DonBond's Avatar
That's pretty low profile which is my primary concern. Looking fwd to your evaluation.....I will probably follow suit. Hit me up with a part number and I'm on it.
Old Nov 28, 2022 | 06:25 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
I don't mind the drain plug because removing the shield isn't a big deal on a lift, but I am in awe of the placement of the oil filter and the drama associated with replacing it. I thought long and hard about relocating it, but could never come up with a better location. Anyone done a remote mount?
Old Nov 29, 2022 | 12:35 PM
DonBond's Avatar
No....I've made my peace with it..... I let oil drain for 24 hours then place rags below filter and immediately tip upright Up and out after removing plenum of course. No mess
Old Nov 29, 2022 | 03:01 PM
zuman's Avatar
I'm with Don. It's a pain to have to remove a throttle body and there's always a little bit of spillage, but my breakthrough was using oil filter pliers to break the filter loose. I think I tried every filter wrench made with no luck, but I've now gotten very comfortable with my Channellock pliers (tighten by hand/loosen with oil filter pliers). Now 4884, if anyone could come up with a remote mount, it's you!
Old Nov 29, 2022 | 03:08 PM
DonBond's Avatar
I use those pliers also.....That's the ticket to success.
Wildcat1212
Dec 21, 2022 03:41 PM
goto35
May 15, 2019 12:49 PM
semicycler
Jul 29, 2014 05:04 PM
mikes996turbo
Jan 30, 2013 11:01 PM
slicky rick
Jan 22, 2013 01:49 PM
