2006 DB9 - Can someone please help me identify this sound? Video attached
Old Jan 10, 2023 | 06:02 PM
goudhabuddha's Avatar
goudhabuddha is infamous around these parts
I’m not confident as to what it is. Doesn’t go away if I turn off AC. It tends to go away after driving a while, particularly when letting the car get higher in the rev range. My main suspicion is the belts (idler belt?) are original and noisy, but I would like the collective ears of this community to let me know if this is something else entirely.
File Type: mov
Old Jan 10, 2023 | 10:50 PM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
Is it the same high pitch you are referrring to in my video around the 1.06 minute mark?
I believe this is the fuelpump. Mine has been making that noise for the last 8 years without causing any issue
Old Jan 11, 2023 | 07:09 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
My 2007 has been making that sound for the last 4 years or so. My mechanic suspected the oil pump, but the sound is too 'dry' IMO and comes from the back of the engine rather than the front. I've always suspected the front propshaft bearing was going and making that noise. It's on my list to check out one of these days.
Old Jan 11, 2023 | 04:19 PM
Originally Posted by sdekoning
Is it the same high pitch you are referrring to in my video around the 1.06 minute mark? https://www.youtube.com/watch?v=z2COg5_T91I
that’s 100% the same sound. Fuel pump prices aren’t awful (500-800 depending used or new) so it could be worth checking. As far as I can tell there are no other issues from the source of this sound, which means it’s getting bumped down in priority to fix
Old Jan 12, 2023 | 05:14 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
On the volante the fuel pumps are pretty easy to get out.... On the coupe you have to drop the tank which is pretty painful!
Old Jan 16, 2025 | 04:45 AM
juhav's Avatar
juhav
Hi,
Does anybody with this noise checked their propshaft bearings? I have same noise at 06 db9 and I’m suspecting also propshaft bearings, but it is quite a work to just check.
Old Feb 21, 2025 | 02:52 AM
Hamodi's Avatar
Hamodi
Mine makes exactly the same noise as OP’s car. Usually begins about a minute after starting the car and being left on idle. Tends to disappear if I blip the throttle gently a few times.
Did anyone manage to resolve?
gtmule
May 6, 2021 07:42 PM
silvertonesx24
Jul 16, 2020 02:02 PM
K9COP
Aug 15, 2016 09:22 AM
Porsche356
Aug 15, 2011 10:01 AM
MegaLoL
Nov 19, 2009 07:55 AM
