Oil Leak
Old Feb 19, 2025 | 01:38 PM
likwidplastik's Avatar
likwidplastik is infamous around these parts
Oil Leak
Noticed a leak when I was working on the brakes. Nothing on the garage the floor at all, and it drives perfectly. Any ideas on what the source could be?
2010 V8 Vantage
Old Feb 19, 2025 | 02:02 PM
V12Vin's Avatar
V12Vin
Love that hand thingy.
Assuming this this is towards the back of the car...do you have a sport shift? I am guessing that's the hydraulic pump [2nd and 3rd pic].
Old Feb 19, 2025 | 08:42 PM
Yeah, this is towards the back by the transaxle. I do have a sportshift.
Old Feb 20, 2025 | 10:07 AM
V12Vin's Avatar
V12Vin
If it also leaks above that pump, then it's the valve accumulator assembly. #17 in this pic: https://www.scuderiacarparts.com/ima...9YJT3CPUQC.gif
not a tech by training, but I would clean up everything, go for a short drive then check again to confirm where the leaks come from.
Old Feb 20, 2025 | 01:36 PM
J doubleU's Avatar
My money is on the mag plate sensor. Probably the most common on SS 1 system.
Old Feb 22, 2025 | 09:32 PM
Thanks for the suggestion. I'll definitely take a look at that.
Old Feb 22, 2025 | 09:36 PM
Thanks for the reply. I'm not familiar with a "mag plate sensor"? A quick google search didn't turn up any results either.
Could you provide a little more detail on that?
Old Feb 23, 2025 | 05:45 PM
J doubleU's Avatar
#12 on the above link. Hopefully that helps.
Old Feb 24, 2025 | 05:15 PM
Thanks! I'll check that as well.
Old Feb 24, 2025 | 06:15 PM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
I wouldn’t get totally freaked about a drop or two of oil……It’s almost impossible to have a car of this complexity without oil seeping from somewhere…..
Frank ( Sunnyside )
Bentley
Feb 16, 2025 12:29 PM
spainconection
Mar 31, 2021 05:53 PM
Carlitos way
Nov 23, 2015 04:56 AM
PhoenixRising
May 11, 2014 11:32 AM
Savile Row
Nov 15, 2012 07:31 AM
