2011 V8V PCV question
Old Feb 19, 2025 | 02:25 PM
mthdr's Avatar
mthdr is infamous around these parts
Redpants had a video or a page on his website that mentioned the PCV valve buzzing as a sign it needed replacing. I have done this and it went away for a bit, but is back when the engine is cold and goes once it's warm.
Starting to prep for the annual oil change I noticed there is oil seepage on the lines that come out of the valve covers which I'm guessing are part of the PCV system. Do these need replacing as well? Are they failing causing oil to be pushed past them?
Old Feb 20, 2025 | 01:35 PM
J doubleU's Avatar
Engine looks as if it hasn't been cleaned in a decade. Personally I'd start with a clean Engine before I decided to change parts.
Old Feb 20, 2025 | 08:03 PM
mthdr's Avatar
Fair point. Thanks.
Old Feb 20, 2025 | 09:09 PM
J doubleU's Avatar
My preference is Simple Green, apply lightly over everything in the bay, and more on the suspected areas on a cold engine. Run it to operating temperature and rinse whilst running with light spray. No pressure washing needed. Allow to keep running until dry, unless you have a leaf blower or compressed air to aid in drying.
Old Feb 22, 2025 | 06:41 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
I need to clean my engine bay too...
By "light spray", do you mean just a garden hose?
Do you need to protect electronic connections before you spray / rinse?
Thank you.
Old Feb 22, 2025 | 07:29 PM
J doubleU's Avatar
Just use best judgment and avoid direct hard spray on any electrical connections as they are sealed for the most part. Good spray from garden hose or if using a pressure washer be very light around them.
Ideal to run the engine to help dry and a big plus is compressed air to dry connectors. Make sure to be light around the under hood fuse box and make sure it's clipped into place beforehand. Don't focus on extremely spotless as you can always rinse and repeat. Hope that helps.
Old Feb 23, 2025 | 06:51 AM
sweet991S's Avatar
5 Year Member
sweet991S
Spot on JAY W......thank you!
Old Feb 23, 2025 | 09:43 PM
EJ_Rapide's Avatar
Thank you sir!
Old Feb 24, 2025 | 05:12 PM
ragingfool35's Avatar
ragingfool35 is infamous around these parts
is this a "cleaning engine bay" thread?
Old Feb 25, 2025 | 03:28 PM
mthdr's Avatar
Is this better? Spray with simple green cold then water once it warmed up.
Old Feb 25, 2025 | 05:45 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Much more loved..lol
xjjeepman
May 26, 2022 06:54 PM
baziturbo
BMW //M
Nov 8, 2013 02:11 PM
CodeBlue911
May 5, 2013 06:44 PM
arktos
Cayenne 958
Apr 28, 2011 01:21 PM
MRC
Cayenne 958
30
Jan 8, 2011 09:20 AM
