ODB2 scanner upgrade
Old Feb 22, 2025 | 06:02 PM
AM-DB9.2's Avatar
AM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of light
Just an FYI...
I had already owned a Foxwell NT-530 prior to buying my DB9 so i added the AM software to it - all in $290
I had been looking for something better over the past two years and did some research lately and found a new scanner, after i bought it i put the Foxwell scanner up for sale immediately!
This thing is light years ahead of my old Foxwell. It's kind of like going from the old Blackberry phone to a new iPhone.
It's the Thinkcar Thinkscan 689. Its only a bit more then the Foxwell at just over $400.
They have a BT option but i went for the wired version because it displays the cars battery voltage in the page header (next to the wi-fi signal strength), so i bought a cable extender for $10 which allowed me to monitor the transmission fluid temp from under the car.
Its all cars and all updates for life. The AM section is very impressive, i think it would take days to go through all of the data monitoring options and what they do.
One thing i learned the 1st time i connected it up and started going through the menus is it said i have two keys programmed to the car.
Old Feb 22, 2025 | 06:53 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Do you need a specific AML software?
Or the scanner will work on every brand?
Old Feb 22, 2025 | 07:03 PM
AM-DB9.2's Avatar
NO, it already has every brand.
Old Feb 23, 2025 | 02:44 PM
AstonLive's Avatar
AstonLive
Would be interesting to know if Thinkcar is also supporting the V12´s with the Bosch ECU (e.g. Vantage 12S)? On their website the car coverage information is a little bit tricky to use.
Old Feb 23, 2025 | 10:23 PM
AM-DB9.2's Avatar
I don't know off the top of my head which models/years used the bosch but i would be surprised if it didn't. I have a 2013 V12
Old Feb 24, 2025 | 04:57 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Checking into this for my DB11 V12. Would be a first if this tool covers it. So far cannot find any tool to cover all systems. It appears it does cover the DB11 V8 version which is easier being MB...but it's the AM V12 that is the challenge.
Old Feb 24, 2025 | 08:35 AM
kilog's Avatar
5 Year Member
kilog is infamous around these parts
The "all cars, all updates for life" thing is a huge selling point. I might have to look into that when my current scanner kicks the bucket.
Old Feb 24, 2025 | 11:50 AM
ram_g's Avatar
5 Year Member
ram_g
Speaking of keys, does this have the ability to program keys to the car? Assuming you get a new one with the seed codes, etc.
Old Feb 24, 2025 | 07:38 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
I’m told the Thinkdiag does..I have a nt530..but will pick up a thinkdiag as well…
Old Feb 25, 2025 | 06:26 PM
AM-DB9.2's Avatar
I was just doing some monitoring after replacing two o2 sensors and in one of the menus i saw 2014 Vantage Bosch ECU - didn't notice a V8 or V12 text
GA_DB9
Apr 15, 2024 07:07 PM
Ashman_E
Jan 20, 2024 02:44 PM
British
Bentley
Dec 2, 2022 08:17 AM
Puddlian
Aug 16, 2020 04:45 PM
wysoseereeus
Mar 11, 2020 08:50 AM
