V8 Vantage Leak - Near Front Timing Cover
Old Feb 15, 2023 | 06:54 PM
amv8ma's Avatar
amv8ma is infamous around these parts
Has anyone had a leak from that line going into the lower part of the front timing cover? Mine is leaking from that black line going into the bottom part of the front timing cover, next to the oil filter.
Old Feb 16, 2023 | 05:45 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Common leak. Is it really leaking or a just a weep?
Old Feb 16, 2023 | 02:11 PM
amv8ma's Avatar
Just drips one or two drops from that line, no leaks from the timing cover itself. Any idea what the part number for an O-ring or seal for that is?
Old Feb 22, 2023 | 01:41 PM
SLVRon's Avatar
5 Year Member
SLVRon is infamous around these parts
I don't have the part number, but the 'fix' is to upgrade to the 4.7 gasket. The good news is that parts are cheap for the fix - the bad news is that it's 20-24 hours of labor to get to it ;( I had the leak in my 2007 Vantage fixed last summer.
Old Feb 22, 2023 | 02:16 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
I had my 2015 V8 GT fixed under warranty - the gasket was not installed correctly at the factory. If it's a weep (many weep) leave it alone, because the fix means pulling the entire suspension apart and dropping the engine to access the fix. The cure might introduce a ton of new problems. My 2011 weeps - I live with it.
Old Feb 22, 2023 | 02:40 PM
downeaster1's Avatar
downeaster1 is infamous around these parts
My 15' GT is at the dealer now getting it replaced under warranty. This will be the second time it's been replaced, and it just hit 14k miles.
Old Feb 23, 2023 | 07:14 AM
5 Year Member
My '11 Vantage use to leak too. I think I was quoted just under 6K to fix at the time. If I drove it regularly it would weep. If it sat over a week or two there would be drops on the floor.
Old Feb 23, 2023 | 07:34 AM
Prefurbia's Avatar
So did you fix it ($6K)? Mine is a weep, no drops of oil. Bamford Rose on YouTube addresses this prescribing the 'live with it' approach if not bad.
Old Feb 23, 2023 | 07:59 AM
5 Year Member
I traded the Vantage in on the Rapide. That was one of the reasons, among a few. If I buy another V8V, I will ask for an impromptu request to see the car on the lift and check to see if it's leaking.
Old Feb 23, 2023 | 08:15 AM
Prefurbia's Avatar
I bought my Vantage from Fairfield Jaguar - I requested a video showing me any leaks or seepages. Either they cleaned up the seepages before the video they sent or avoided the areas. Today I would have used Lemon Squad who were instrumental in helping me find a no issues SLK32 recently. Had I used them I would have either bought a different Vantage or offered $10K less.
Old Feb 23, 2023 | 08:45 AM
5 Year Member
That's exactly why I would request an impromptu inspection on a lift. Beat them to the punch if it's leaking. No time to clean it.
Old Feb 23, 2023 | 06:21 PM
amv8ma's Avatar
Its not the front timing cover gasket, it's the black line going into the front timing cover which is leaking. The line which takes a 90 degree turn which is next to the oil filter. I didn't know if anyone has ever experienced this issue.
Old Feb 24, 2023 | 05:20 AM
MRCW's Avatar
This is the approach I've taken with my 2009. During the PPI with original owner present, the tech noted a slight weeping.
I was quoted about $3k to repair and the original owner agreed to knock $2k of the price for that...
Decided to wait to repair to see if it would get worse. Hasn't leaked in 5 years and a slight weeping I wipe up every year during my oil change. Has never dripped anything on the floor
Old Jun 30, 2025 | 04:44 PM
GWP's Avatar
GWP
5 Year Member
GWP is infamous around these parts
If anyone of you are considering trying the seal repair yourself I think I have the correct seal and gasket set for the 4.3 & 4.7 engine. 95% but not 100% sure but would be happy to mail a set to you N/C for testing and confirmation.
RudyP
Mar 3, 2022 08:26 PM
PJK
Jul 15, 2021 01:13 PM
bunob
Oct 28, 2019 01:50 PM
Golfpunks
Jan 26, 2018 11:33 AM
