bulb Failure dipped beam but lights are working fine.
Old Mar 18, 2023 | 12:42 PM
peerware's Avatar
peerware is infamous around these parts
Hi, today i got the second message in a month about 'Bulb failure dipped beam' but the lights are working fine and the message goes away when i restart the car.
I'm thinking either a bad connection or a ballast going bad. Is there a way to check which side it is, i have the foxwell scanner. if i know which side i can switch the ballasts and see if the issue switches sides with it.
(2004 db9 v12 with hid)
Old Mar 19, 2023 | 04:02 AM
peerware's Avatar
I was playing around today and i found 2 light related messages:
-B0D06 Right brake lamp circuit open
-B0A09 Right low beam circuit open <-- this looks like the cause of the message. Reading live data it does not show any issue. Voltages left and right are the same.
I guess i need to wait until the problem is more consistent to find this issue, but the message is really annoying.
Old Mar 19, 2023 | 10:36 AM
MRCW's Avatar
Have you tried clearing the codes with a Foxwell or other scanner?
simpleman325i
Cayenne 955/957
28
Aug 5, 2022 07:51 AM
All
Cayenne 955/957
Aug 8, 2017 09:26 PM
RobsCountach
Cayenne 955/957
Nov 27, 2014 10:06 AM
MeanMachine
Cayenne 955/957
20
Dec 29, 2013 01:53 PM
mattjtaylor50
Cayenne 955/957
Feb 28, 2009 02:53 PM
