Retrofitting radio ac control in db9
Old Jul 13, 2023 | 09:05 PM
trainwreck's Avatar
trainwreck is infamous around these parts
Does anyone know if retrofitting the infotainment unit from newer db9’s into an older model works. Is it just plug and play. Anyone done it?
Old Jul 14, 2023 | 06:56 AM
embdenb's Avatar
I don’t know for sure, but by guess is it will not work. I believe that the control inputs are different
Old Jul 14, 2023 | 01:22 PM
SloMoShun's Avatar
SloMoShun is infamous around these partsSloMoShun is infamous around these parts
while I haven’t personally tried, and thus can’t answer with absolute certainty, I doubt it is possible If it was just plug-and-play the everyone would be doing it and this board would be full of retrofitted first-edition DB-9’s. As it is, I haven’t seen a one. The dash insert contains not just the infotainment controls but the HVAC controls as well. The HVAC CPU is a dedicated unit with EPROMS. I’d be shocked if the later models didn’t have updated CPU’s with altered programming. So even if the new dash insert physically fit and the connectors were the same, the new controls couldn’t talk to the old CPU. Probably same for the stereo, the nav system, the reading lights and anything else controlled from the early DB-9’s center stack.
Old Jul 14, 2023 | 02:27 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
I solved this problem by driving in a lower gear. The engine noise makes up for the lack of options with the infotainment system.
Seriously, in my 06 on the highway I am impressed that I can listen to the stereo over the engine/road noise. Just did a nice 40 miles on the highway to look at a car and the journey was the best part of the trip!
Old Jul 14, 2023 | 08:13 PM
trainwreck's Avatar
Yeah. I was just curious. As I’m looking for a solution to the crazing on the polarized display. I didn’t expect it would be a tough fix. But as research has it. I can’t justify the cost of a new replacement. I don’t mind spending on repairs. But in the case of $3-4k on a radio/Hvac display is not worth it in my opinion
Old Jul 15, 2023 | 01:55 PM
embdenb's Avatar
The polarized film on the radio display can be removed.
https://bernardembden.com/am/radioscreen/index.htm
Old Jul 22, 2023 | 09:37 PM
trainwreck's Avatar
Thanks for that info. Will definitely be doing it
txtonyo
Jan 17, 2022 09:05 AM
sliderule01
Dec 14, 2021 02:43 PM
broncoupe
Nov 8, 2021 07:08 AM
jyu12
Feb 3, 2014 10:37 PM
jmargolese
Apr 13, 2013 02:40 PM
