Pesky headlight assembly connector
Old Oct 3, 2023 | 02:06 PM
seenastyle's Avatar
5 Year Member
seenastyle is infamous around these parts
Any tips on how to disconnect this connector behind the headlight assembly/housing? It seems that it might need to slide laterally (left/right wrt the car)? Do I have to remove the headlight assembly and/or fender liner, or can I disconnect this in place?
File Type: mov
Old Oct 3, 2023 | 06:28 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
The red piece on the right hand side goes further to the right. About 8mm or so. Once you do that the connector will slide out. I use a pick or small screwdriver to gently pry it open. Some dielectric grease will make it easer the second time...
Old Oct 4, 2023 | 04:51 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Yes, agree. Similar to this connector:
Old Oct 10, 2023 | 05:31 PM
seenastyle's Avatar
5 Year Member
Thanks all for your help, I was able to get it disconnected rather easily once I understood how it works. Here are some photos which hopefully help others following my footsteps in addition to BWings' which is probably better:
Old Oct 10, 2023 | 06:32 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Thanks for posting..I’m sure it’s gonna come up at some point…just done contact clean and dialectic grease on all the joints of my ram3500..time well spent I think..lol
XWCGT
Dec 3, 2015 08:35 PM
BLKPPR
Cayenne 955/957
May 16, 2011 11:15 AM
griggsat
Aug 21, 2010 12:39 PM
motoadve
Cayenne 955/957
Nov 20, 2008 09:36 AM
