Magnetic Drain Plugs
Old May 7, 2024 | 10:57 AM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Which source do you members usually use when sourcing a magnetic drain plug?
I am thinking oil pan plug / differential plug / transmission pan plug.
Do you recommend specific brands / suppliers?
Thank you!
Old May 8, 2024 | 03:31 PM
J doubleU's Avatar
Differential already has one on your car, and the transmission pan has 2 fixed to the bottom of the pan. Engine is the only one you would need. Should be easy to source.
Old May 8, 2024 | 05:15 PM
EJ_Rapide's Avatar
Thank you for the clarification, JW!
Old May 13, 2024 | 01:28 PM
khiroshima's Avatar
khiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond repute
I cannot take credit for the find, but I can verify the fit and usage in my 2019:
Thread: https://www.6speedonline.com/forums/...il-change.html
Credit: AcidLime
Plug: M14 x1.5 Magnetic Oil Drain Plug...
Amazon Amazon
Good luck, easy job-- KH
OPPS, you were asking about a 2010 Rapide - Ignore
MadWhip
Nov 7, 2014 04:08 PM
tphss
May 20, 2012 08:23 AM
iceman153
Apr 26, 2012 05:43 PM
porschedude996T
Sep 19, 2007 06:11 PM
