Rapide S Misfire Correction
Old Jun 10, 2024 | 08:55 AM
zzzamdb9's Avatar
5 Year Member
zzzamdb9 is infamous around these parts
Hello,
I know on the DB9 the misfire corrections need to be relearned after disconnecting the battery. I thought I had read somewhere this only applied to pre 2011. Does anybody know if a 2014 Rapide S also requires misfire correction relearning after disconnecting the battery? Or is it saved now? Thanks!
Old Jun 10, 2024 | 07:01 PM
mbrandt1402's Avatar
mbrandt1402 is infamous around these partsmbrandt1402 is infamous around these parts
From discussions with VAP about their ECM tune, the misfire corrections are not affected by disconnecting the battery. They are in a non-volatile memory that can only be cleared with diagnostic software like the AMDS system.
I was asking if they could load an empty misfire table with their ECM flash, but the flash can't address the memory where the misfire corrections are stored.
Immanuel
Oct 30, 2024 05:15 AM
EJ_Rapide
Feb 26, 2024 07:56 PM
slxkrdb9
Mar 26, 2017 08:21 AM
dan87951
Apr 23, 2014 05:14 PM
jyu12
Mar 14, 2014 01:20 AM
