2007 AM Vantage, high can issue, car will not start
Old Oct 27, 2024 | 07:45 PM
Frankyboy's Avatar
Frankyboy is infamous around these parts
Hi guys,
This is a 2007 AM Vantage with a High CAN and Low CAN issue so I couldn´t start the car. The car had an small accident and now I´m rebuilding it.
I have an original AMDS System for better testing. I did all the testings regarding Canbus, checked resistance (60 ohms), tested short circuit
to ground and to power. DIM is not working, I only could see the engine light. Swapped the DIM, no change. Checked +/- on the DIM plug, checked
short to +/-, nothing. Could access every module by AMDS except DIM, tested with an oscilloscope the Canbus, voltage and communication seems okay for both circuits.
swapped the BCM, nothing.
Does anybody of you guys have an idear what I could do next ?
Thanks to all
Old Oct 29, 2024 | 08:00 AM
V12AM's Avatar
V12AM is infamous around these parts
Where are you taking the resistance and scope readings from?
Old Oct 29, 2024 | 09:24 AM
chrzesm's Avatar
5 Year Member
chrzesm is infamous around these parts
Are you sure your CEM works ok? It should send CAN messages waking up the DIM. Do you have CAN analyser to see if the CEM sends anything to DIM? DIM can be initiated with CEM frames on Low Speed CAN: EC353BC 01 00 00 00 BD 8E FF 7A or EC353BC 01 00 00 00 BD 98 00 85. I would check if you see CAN signals directly on DIM socket, it seems to me you have CAN lines broken between DIM and CEM. To start the engine DIM should send matching VIN, otherwise ECM will not crank.
Old Oct 29, 2024 | 05:13 PM
Frankyboy's Avatar
Hi V12AM,
I was measuring on the OBD port and I used the chassis of the vehicle as ground. Furthermore I have tested CAN BUS communication with an simple OBD testing tool (CTB007)
I have measured HI CAN and LOW CAN on the same time.
Old Oct 29, 2024 | 05:21 PM
Frankyboy's Avatar
Hi chrzesm,
you are right, the DIM works on the CAN BUS LOW, and I made a continuity test on both lines (marked red) between CEM and the DIM (green plug)
which was okay,
Old Oct 29, 2024 | 05:47 PM
Frankyboy's Avatar
Hi,
furthermore I have the error "fuel system disabled", might have something to do because of the DIM issue.
What I did in the meanwhile:
Checked the fuel pump: OK
Checked the fuel pressure (in range): OK
Checked the fuel ECU, behind subwoofer, driver seat: OK
Checked the pyro fuse: OK
Had a strange issue when I disconnected the "INFOTAINMENT CONTROL MODULE" (behind center dashboard) after I turned on the ignition some modules came back online.
But I couldn´t replicate this behaviour, maybe it was just a bug from the software, I don´t know.
Old Oct 29, 2024 | 06:21 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
This thread is like a mainline injection into my veins.... Thank you for posting!
Old Oct 29, 2024 | 08:12 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
P1233 - The fuel pump driver module is offline. There's a fuel pump monitor signal from the pump driver to the PCM. Either the fuel pump driver module is not getting power or the monitor signal is not getting back to the PCM.
The DIM lives on and terminates the end of both LS and HS CAN bus. Pin 2/3 is the low speed canbus. The other end is terminated by the airbag module. Pin 4/5 is the high speed canbus. The other end is terminated by the ABS module.
Old Oct 30, 2024 | 02:34 AM
chrzesm's Avatar
5 Year Member
I would suggest to check if you can see CAN waives between pin 2 and 3 on the green plug. The DIM should wake up as soon as it has power supply and proper Low CAN communication with CEM. Engine MIL light is completely isolated and powered from ECM, so it does not say if DIM is properly powered. So you should see: GND - pin 30, +12V - pin 1, CAN signal - pins 2, 3.
Old Oct 30, 2024 | 02:44 AM
chrzesm's Avatar
5 Year Member
Originally Posted by Frankyboy
Hi,
You need to fix the DIM issue first as DIM sends its VIN data. ECM will not activate the engine components until the VIN data from DIM, CEM match with ECM.
Old Oct 30, 2024 | 03:25 AM
Frankyboy's Avatar
Hi chrzesm,
could it be that the ECM are faulty ?
Old Oct 30, 2024 | 04:51 AM
chrzesm's Avatar
5 Year Member
Hi chrzesm,
It is quite rare case. Check the wiring first. If the wiring is ok, I would just plug in CEM from any other Aston (w/o reflashing) and if DIM is alive, your CEM needs to be a) reflashed to your VIN, and if it does not help b) replaced. Are you sure the CEM is original one, ie no-one just pluged in a volvo flashed part taking out the original Aston programmed unit? Can you share the CEM numbers (printed on the case, not a label)?
Sorry, I just realised your CEM is visible by AMDS, and I assume when you start the diagnostic session the ECM's VIN matches with CEM VINs, otherwise you will receive a warning message. So for sure you have an original CEM in your car.
Please remember not to try to start the engine if you plug other car's DIM or CEM, otherwise your mileage will be compromised. You can have an ignition on, however do not crank the engine before you reflash DIM or CEM for your VIN.
Old Oct 31, 2024 | 11:58 AM
J doubleU's Avatar
Not stating this is your issue but, lot's of CAN issues with CRM which they take out the display on the DIM and take down the infotainment. I would disconnect it just for testing purposes and hopefully everything plays nicely.
Old Nov 1, 2024 | 04:15 PM
Frankyboy's Avatar
Hi @J doubleU
yes, I tried that already, thanks. I will continue in about 2 weeks, then I have more time and will dig into the problem again. Did changed the CEM module, didn´t programmed it but DIM still down.
Bought some other modules on ebay, ROOF ECU, fuel pump module, CEM, ASM ECU, DIM, will swap some more modules on the Can Bus or disconnect them unitl everything is up again.
@chrzesm = will try what you suggested, will post the results.
@GA_DB9 = tested the +/- on the fuel pump module, measured the fuel pressure, which was okay so fuel pump seems okay.
Just wondering why bank 2 is showing nothing, and bank 1 is just too low......so it seems fuel is not reaching both fuel banks
but checked fuel line to the banks.
JKhlok
Sep 13, 2023 07:22 PM
510michael510
Jun 29, 2023 05:35 AM
Dustan
Nov 29, 2018 05:33 PM
Bernmish
Sep 3, 2017 07:18 PM
clint_lonestar
Jan 15, 2013 01:52 PM
