Window Module - 2007 DB9
Old Nov 17, 2024 | 01:52 PM
sliderule01's Avatar
sliderule01 is infamous around these parts
At the present time, after multiple resets, my driver's side side windows either doesn't drop, or go up properly when the door is opened or closed. I suspect it is the door module. What is the part number for the module - is it 6W6Z13C788AB?
Scott
Old Nov 18, 2024 | 09:08 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
Before you replace door modules check the door latch and the push/pull cables for the exterior door handle and key lock. The door latch microswitches can fail and the door module won't know what position the latch is in. The outer sheath of the cables can snap and prevent proper locking/opening. In my case both the key lock cable and the door latch had failed causing unreliable window drop on my passenger window. It's a lot cheaper to replace those two than to have the door modules swapped and re-coded by a dealer.
Old Nov 18, 2024 | 11:10 AM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Did you have to remove the door panel to fix that?
Or "just" the door handle?
Old Nov 18, 2024 | 12:07 PM
GA_DB9's Avatar
5 Year Member
The door card, window glass and window regulator all have to come out to access both. I did it a couple times and as long as you give yourself a couple of witness marks on the glass and door it's pretty easy to get the glass back in and lined up.
thom_77
Sep 19, 2024 05:07 AM
Chris P
Mar 17, 2018 01:34 PM
LIDB9
Oct 24, 2015 01:07 PM
trwnsgy
Nov 23, 2014 06:48 PM
jyu12
Mar 10, 2014 11:49 AM
