What an amazing battery
Old Jan 16, 2025 | 10:11 PM
AM-DB9.2's Avatar
AM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of light
Time to swap out my battery, not because it’s acting up and failing or discharging fast, but because this Deka battery has a date code of 1/17 and is 8 years old.
I have never had a battery last this long, ever, maybe 5 to 6 years max.
So hats off to Deka, for this battery at least!
Old Jan 16, 2025 | 11:47 PM
V12Vin's Avatar
V12Vin
Is that an OEM? I need to check mine soon.
But for data point comparison, I recently swapped one out that was 10-year old and original in my 911. Likewise, no funny symptoms. Got a good deal on AGM.
Old Jan 17, 2025 | 06:08 AM
embdenb's Avatar
Replace with an AGM
Old Jan 17, 2025 | 02:20 PM
AM-DB9.2's Avatar
No, it's aftermarket lead-acid.
10 years, nice. Hard to get 5 here in the desert.
Old Jan 18, 2025 | 07:19 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
That's not too surprising when the battery is in the cabin and kept cool. When we lived in Phoenix our kids' cars on the driveway and battery under the hood would only last a few years. Both of our cars with batteries under the seat and kept in the garage would last almost 8 years at a time.
The Bosch AGM I put in the DB9 is going on 6 years and still cranks like new.
Old Jan 18, 2025 | 02:35 PM
ram_g's Avatar
5 Year Member
ram_g
Originally Posted by embdenb
Replace with an AGM
There is no AGM available in the T8 size needed for the 2013+ DB9s. The H8 specified for the earlier cars does not fit.
Old Jan 18, 2025 | 06:26 PM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
if anyone's interested:
After getting very inconsistent results trying to run battery health tests via the engine bay charging/boosting power posts, have fitted this little gadget (BM300 Pro) directly onto the battery and can monitor its health and crank capacity continuously. It draws very little power on its own (1mA) when logging and it helps me see the alternator charge current and the trickle charger activity directly on my phone. The range is good enough to do it from my phone over Bluetooth at home while the car's in the garage. It can be had for about $23 (incl ship!)
Old Jan 19, 2025 | 11:47 AM
ram_g's Avatar
5 Year Member
ram_g
Good tip, @UltraMarine. Looks to be $55 on Amazon. Any other source you recommend?
Old Jan 19, 2025 | 01:55 PM
Sure, paid $23.39 +tax (incl. Shipping) here:
https://www.aliexpress.us/item/3256806824625952.html
There's also a cheaper BM200 that seems to do similar
Old Jan 24, 2025 | 05:25 AM
sweet991S's Avatar
5 Year Member
sweet991S
Thanks all! Just ordered one but, as I have a new battery (Oct 2023), I will install it on my '03 Jeep TJ, which is on a trickle, but outside......cool piece of gear assuming it works right. Thanks for the tip!
embdenb
Feb 16, 2020 06:15 PM
TrueGuardsRed
Feb 7, 2014 09:17 AM
michaeldantep
Apr 8, 2011 06:53 PM
WILLIAMHENRY
Jan 11, 2010 11:51 PM
