Vantage rear wheel arch liners removal
Old May 7, 2025 | 11:22 AM
Jorgens's Avatar
Jorgens is infamous around these parts
Hi all! So I need to access the vacuum pump for the exhaust. Had a look today, and saw a combo of screws ans rivets. 06 model. So do you drill out the rivets? And if so, what should I replace them with?
Cheers
Jørgen
Old May 7, 2025 | 02:32 PM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
Mine is a 2015 so might be different, but no rivets to drill. Just screws, rivets may be holding parts to the liners, but not the car itself. It's been quite awhile, but I would not drill any rivets.
Old May 8, 2025 | 03:11 PM
Percy Penguin's Avatar
Percy Penguin
Definiately no need to drill anything. Just a few philips screws and a couple of torx fixings, and one 'scrivet' (a plastic screw) on the subframe and then the liner can be pulled out. The rivets hold the heat shield to the liner, and don't need removing as it all comes away as one piece.
JPS-ATL
Aug 12, 2019 01:12 PM
slo1911
Aug 8, 2013 09:40 PM
brumma
Jul 31, 2011 09:01 AM
astonfan
Mar 9, 2009 07:46 AM
