Carbon Ceramic Brake Kit: Vantage, DB9 etc
Old Aug 7, 2024 | 04:58 AM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
For sale: dekitted from my 2004 DB9 this full set of the larger Caramic Brake rotors + matching rear steel rotors. This set will fit all VH-models from 2004 up through 2013, 2014 with steel brakes. I have had the set installed on my standard 19" early DB9 rims but ideally they are fitted on a 20" and larger wheels.
The set is complete and you will only will require:
- a new set of 2 to 3" longer front brake lines.
- a set of rear-spacers between 15 - 18mm thick (front carbon rotor already includes a 13mm spacer)
- longer wheelstuds (M14 x 2). I had 70mm long versions
This set is a straight swap. You will use your current front 4-pot calipers for the rear-axle to accomodate the larger drilled disks. I will include a set of transfer stickers so that you can paint the 6-pot BREMBO calipers from your kit in matching colours with your rear-calipers.
I have had the set on my DB9 for 25k miles and had both rotors re-surfaced before fitting the kit. The current PAGID RCS3 pads are between 13.5mm and 16mm thick. From new they are 16mm thick which means there's plenty of meat left (84% +). De rotors are in great condition given their age and life.
Pictures says it all. I'm based in Cyprus but can easily export-pack the set. Indicative price I'm looking for is USD 7.5k + shipping costs (thru wire).
Touch base if you are interested and would like to get more info. Regards, Simon
Ray F
Feb 25, 2023 01:19 AM
sdekoning
Jan 3, 2016 10:29 AM
ilahi155
Feb 22, 2015 08:50 AM
blue_skies
Jul 30, 2013 05:23 PM
XJRS Owner
Sep 13, 2009 06:33 PM
