Bentley Gen 2 GT all models FS all models Mulsanne
Convertible Fault code ?
Old Jan 21, 2026 | 05:37 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
2015 continental convertible which has a roof fault code (photo). It’s been operating perfectly for 6 years of ownership however a few weeks ago it threw an orange “roof fault” symbol on the dash. It continued to work fine and I put it down to an over sensitive sensor due to lack of use recently.
When I press the button down to drop the roof, I hear the windows attempt to drop with a very small thud/click and nothing else, same when I operate the button up - it makes the same attempt, I assume the reverse. However the roof doesn’t move, it’s in its closed position. All the windows operate normally, batteries are good, no other issues.
I’ve attached the scan tool error code in the hope someone can help.
My local mechanic cleared the code successfully, then as soon as I try the button again it throws the code again - ever time.
“02461:008 - RIGHT LINKAGE FLAP POSITION SENSOR - implausible signal”
Hoping this is a small fix 🙏
Old Jan 22, 2026 | 06:06 PM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
Old Jan 23, 2026 | 03:45 PM
AJ1's Avatar
AJ1
5 Year Member
Thanks for your reply Bruce, but I had already seen this one with no answers really.
Old Jan 28, 2026 | 11:18 PM
AJ1's Avatar
AJ1
5 Year Member
Anyone ?
stevedavies
Bentley
Feb 5, 2025 10:36 AM
KCA
Bentley
May 12, 2024 04:01 PM
Dr.Disaster
Bentley
10
Aug 7, 2014 08:44 AM
Jeff SD
Bentley
Dec 18, 2013 09:16 PM
White991TT
Bentley
Sep 25, 2013 05:58 PM
