Bentley GT owners, question about possible warning light?
Old May 5, 2021 | 12:56 AM
  #31
Dark Green's Avatar
5 Year Member
Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !Dark Green Is a GOD !
Originally Posted by cerex
Interesting enough I got both errors discussed on this thread.
3rd Brake light out - sourced a new brake light and looking for an indy shop in NU/NY/CT/PA area to sort out, Dealers wants close to $2K in Labor
(P) fault came on, I might be lucky for now as I did the Parking Break engagement 5 times and has since disappeared.
If there is a DIY instruction out to replace the faulty sensor/brake part suspect others might benefit as well.
Many Thanks as always Jonny for keeping us all on track and informed
Alex
Removing the Electronic Parking Brake (EPB) motor really isn’t difficult.
The process, as has been posted before is:
1) Car into Jack mode (if possible)
2) Elevate the car and remove the appropriate road wheel.
3) Follow the convolute tube covered cable from the EPB motor until you find the first connector, and disconnect this (you may need a small tool to release the locking tab).
4) Undo the two Torx bolts which retain the EPB motor to the caliper body.
5) Remove the motor – which may require a screwdriver to lever it out, because the alloy corrodes and the motor body cracks and swells.
6) Clean the corrosion away from the recess into which the motor fits.
7) Fit the new motor and follow other steps in reverse.
There’s a good video here
which shows a typical VW EPB motor being removed, and at 2:45 shows the cracking that is so typical and allows water ingress.
Note that the generic VW caliper used on other models uses a smaller electrical connector mounted directly to the motor, rather than having a motor with a flying lead as per Phaeton/CGT/A8 which has what appears to be a current monitor on the extra two pins.
onefastman1
Bentley
Jul 18, 2022 11:35 AM
Nairb999
Oct 10, 2016 02:44 PM
cduluk1
Bentley
23
Sep 27, 2016 01:16 PM
gogolchris
Bentley
Sep 28, 2014 06:13 PM
Tintin
Bentley
Dec 16, 2013 03:16 PM
