Mobile phone reception issues in 08 GTC
Old May 30, 2013 | 01:37 PM
Phantome46's Avatar
Phantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud of
My dad seems to have a real issue with his Bluetooth phone system in the Bentley. It seems to be very crackly pretty much all the time and also when your on the other end of the call you can hear a bad drone that sounds like loud engine noise in the back ground.
I would have expected it to be very clear but its far from that and does seem to crackle and disconnect regularly?
Anyone have any idea?
Old May 30, 2013 | 05:09 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
have you checked on the bentley website to see if it is compatible . Also,does the car have a privacy handset,
Old May 31, 2013 | 10:30 AM
Phantome46's Avatar
its an iphone 5 and i'm not sure what the privacy handset is?
Old May 31, 2013 | 10:59 AM
go to bentleymotors.com and check compatibility with that version of phone. if fitted the privacy handset will be in the armrest.
Old May 31, 2013 | 11:37 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Has this problem always been this way? It may indeed be a compatibility issue or perhaps a grounding/wire problem.
Old Jun 1, 2013 | 01:04 AM
Phantome46's Avatar
Yes it seems to have always been that way?
Old Jun 1, 2013 | 07:58 AM
Hmmm.... I'd then take it to the dealer for testing.
Old Jun 1, 2013 | 08:07 AM
have you got another phone that has bluetooth compatibility that you can try in car,iphone 5 are compatible as long as you have the latest version of Bentley software in car. Also if you have a privacy phone fitted in armrest ,switch it off and see if any better results are obtained.(to switch off ,leave handset in cradle and depress button until you hear a beep).
Old Jun 2, 2013 | 02:46 AM
Phantome46's Avatar
how do you check on what software version you have in the car?
Old Jun 2, 2013 | 06:53 AM
the car needs to be put on a Vas 5052 or equivalent to read the control module.
Nikg
Sep 21, 2015 10:32 PM
terminal_ac
Sep 12, 2015 03:26 PM
gulf gt
Aug 27, 2015 10:27 AM
awchristler
Bentley
Aug 24, 2015 03:53 PM
Aug 19, 2015 06:55 PM
