conti gt- bank 1 sensor 1 o2 sensor
In the meantime, I’ll continue searching for the harness so I can do some tests with a multimeter.
thanks again!
I‘ve ordered a VCDS cable as I have a few other electrical issues I want sorting. Cable not received yet but will do a full scan and update you as soon as received.
thanks again!
thanks again!
@REDNOSEGT maybe one for you also...... how did you know your sensor needed replaced?
So how did you know your sensor was needing replaced was maybe more my question. Sorry maybe wrong poster....lol
So the only diagnostics I have done so far is using generic obd scan. I would like to measure resistance and voltage across the sensor terminals and perform VCDS scan once cable received.
Hope that answers your question!
Continental GT Gen 2 / Failed Emissions Test.
Hello,
I didn't pass the emissions test, the CO values were too high. The OBD scan shows a faulty Bank 1 pre-cat sensor.
Is it possible to get to the bank 1 per cat sensor from the wheel on a left hand drive car?
heathrow99
Bentley
11
Jul 23, 2020 06:18 AM
