conti gt- bank 1 sensor 1 o2 sensor
Old Jun 11, 2013 | 06:21 PM
REDNOSEGT's Avatar
REDNOSEGT is infamous around these parts
bank 1 sensor 1, this is passenger side pre-cat o2 sensor,
took me and my dad 1.5 hour to remove. remove a small heatshield, remove wheel, drop tie rod, pull filter box, use a long o2 wrench and get it from the top.
sure bentley quoted 40 hours.
macgyver is my middle name
Old Jun 12, 2013 | 03:58 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Send your procedure to Bentley as am sure they'd like to know an easier way
Old Jun 12, 2013 | 07:03 AM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
And lose $? Sure.
Old Jun 12, 2013 | 08:59 AM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
they know the easier way,they just have not updated assist,if done under warranty the factory does not pay for engine removal and if done with customer pay the dealer should not charge for it either !!
Old Jun 12, 2013 | 09:34 AM
REDNOSEGT's Avatar
I know Indy shops told me 8-10 hours
Half shaft removal, shock removed, drop subframe, etc etc
I am not sure how hard the driver side would be
I know the passenger side bank 1 sensor 1, pre cat I did easily
I heard the bank 2 is much harder ?? maybe the steering gets in the way
Old Jun 12, 2013 | 10:00 AM
on the 04 to i think 12MY cars all the O2 sensors can be changed without having to remove engine,if you are thinking of lowering the trans mount to do the rear sensors then that is not recommended because of the stress put on the front electronic mounts.
Old Jun 12, 2013 | 07:53 PM
REDNOSEGT's Avatar
hope i dont get another o2 sensor bad, the o2 is out, now just waiting for the part to come in.ordered original bentley sensor.
Old Jun 16, 2013 | 12:38 AM
Staff@WORLD's Avatar
Staff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to beholdStaff@WORLD is a splendid one to behold
I did a starter in an '07, I couldn't find an easy way around that job. The motor came out for that job.
Old Jun 16, 2013 | 12:55 AM
REDNOSEGT's Avatar
What a pain, no way to drop subframe or anything? Make tools?
Old Jul 26, 2019 | 11:37 AM
yanacha's Avatar
yanacha is infamous around these parts
Hello,
I have to change my sensor 1 bank 2.
Could you explain to me with détails how did you changed it ?
Thank you very much
Old Aug 4, 2020 | 10:00 AM
Abisai Santiago's Avatar
Abisai Santiago is infamous around these parts
what size 02 sensor removal tool did you use? I need to change mine out too. Thanks in advance.
Old Nov 9, 2022 | 12:16 PM
nasser21's Avatar
nasser21 is infamous around these parts
Smile o2 sensor bank 2 location
hi there
i was just wondering ! i have 2014 flying spur that has a faulty o2 sensor bank 2 (P192300 code)and hoping someone will tell me where exactly located please?
Thank you
Old Nov 9, 2022 | 04:31 PM
tteplitzmd's Avatar
5 Year Member
tteplitzmd is infamous around these parts
What year is your Bentley?
Curious if you would share where you got the new sensor part and for how much?
I got mine from Flying Spares, about 50% less than from Bentley dealer.
Old Nov 10, 2022 | 02:57 PM
dangme55's Avatar
dangme55 is infamous around these parts
Ha, ha sure they will. don't flame me I get the sarcasm - gotta luv it.
OBTW - I am posting up a couple of pictures of my EGR secondary air valve that they wanted $500 to replace.
Old May 14, 2025 | 03:49 AM
Hamodi's Avatar
Hamodi
Is bank 1 sensor 2 possible without dropping the engine?
I have a P0141 code for the heater circuit that comes on intermittently. I want to test the wiring/resistance from the harness. Did you take any photos of where the harness connector can be found please? Thanks
