Terminal 30 low volrage ????
Old Jan 12, 2014 | 09:47 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Hi Guys/Dolls,
Thought I would do a health check on my GT Speed using Vas and found numerous faults with the common reference of Terminal 30 low voltage.
I checked each module for eg Dash/display, TPMS, etc all the modules that had the error then cleared them. They all remain clear.
What's the main cause of a terminal 30 low voltage error.
BTW the car was parked for a while before I attached the maintenance charger.....could the battery voltage have gotten a little low standing.??
Thanks,
Frank
Old Jan 12, 2014 | 10:09 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
I believe "terminal 30" refers to unswitched power that is supplied even when the ignition is off. Therefore, a low battery condition could generate the error code.
Old Jan 12, 2014 | 12:16 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
as PMS said,low battery voltage will trigger this code,putting a maintainer on the car is a good idea.
Old Jan 12, 2014 | 01:56 PM
Thanks guys, its what I thought. My Vas 5054 pointed it to that but I recon it was only off the Maintenance charger for no more than 10 days before I put it back on it. Mind you its very cold here and I don't know how old the Batteries are. Perhaps being a late 2008 car they are original.
Thanks again to you both
Frank
Old Jan 12, 2014 | 02:54 PM
PMS's Avatar
PMS
I don't drive my car in the winter so I leave it on a CTEK trickle charger. With temperatures around -25C, my new OEM battery won't last more than about 8 days without being on a charger. There seem to be a lot of unswitched electronics running all the time (e.g. alarm systems).
NIKAS
Aug 20, 2019 07:53 PM
Bmanny
Sep 16, 2015 08:29 AM
MrMiggy
Sep 14, 2015 02:18 PM
mjdVantage
Sep 5, 2015 07:22 PM
