Cigarette socket fuse?
Old Feb 17, 2014 | 03:47 PM
jsmith141182's Avatar
jsmith141182 is infamous around these parts
The front cigarette lighter socket is not working in my '04 Continental GT, anyone know which fuse is for this and it's location? Thanks
Old Feb 17, 2014 | 05:45 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
+1 Same issue.
Old Feb 17, 2014 | 09:40 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
is it left hand drive,if so under steering wheel there is a kick panel that drops down when released . on the lower level of fuses you will find 4 or 5 15 amp fuses(blue) ,i think its about the third one in and you can either test with a test lite (recommended) or remove and see if its blown,common fault on those was for the socket to actually burn out due to aftermarket plugs being installed so fuse may blow instantly.
Old Feb 17, 2014 | 09:52 PM
ExoticCarDriver's Avatar
ExoticCarDriver is just really niceExoticCarDriver is just really niceExoticCarDriver is just really niceExoticCarDriver is just really nice
It looks like it is fuse F84 located under the steering wheel. Once you get to the fuse box, you have to look real closely for the numbers near the fuses as they are very small.
Old Feb 18, 2014 | 01:03 AM
Thanks guys, I'll check it out later
Old Feb 18, 2014 | 11:59 AM
I have a RHD, I tried pulling down the kick panel underneath the steering wheel but it seemed like it was attached somehow? I couldn't see any screws just looked like it was hinged from the bottom of the panel. I didn't want to force it, is it just clipped in place?
Old Feb 18, 2014 | 12:00 PM
use a torch and look along the lower edge and you will see a black pull handle. pull that and it will drop open
Old Feb 18, 2014 | 06:20 PM
jc_333's Avatar
jc_333 is infamous around these parts
Pre MY06 have hinged panel with pull handle whilst MY07 the complete panel pops off with a bit of force.
J
Old Feb 21, 2014 | 03:22 AM
It was a small pull handle to release the drop down panel as you said, then I found a 15A fuse blown on the bottom row.Replaced that and now it's working, thanks again guys
Steve Jarvis
Apr 1, 2023 06:49 PM
adnanm3
Oct 25, 2016 08:38 AM
gliozzi
Bentley
Sep 29, 2015 09:27 AM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
