Neo car audio kit
Old Aug 17, 2014 | 10:44 PM
Gambit's Avatar
Gambit is infamous around these parts
Neo car audio kit
Hey guys. New and proud owner of 2006 bentley gt.
To my surprise I couldn't find an aux input jack in the car, which renders me unable to hook up my iPhone pandora.
Found this unit:
www.neocaraudio.com/products/PVW2GV1BT
Anyone familiar with it?
Old Aug 18, 2014 | 03:49 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
It looks to be an FM transmitter, so lower quality sound capabilities than the Dice unit.
Old Aug 18, 2014 | 11:57 PM
Gambit's Avatar
I don't believe it's an fn transmitter. The unit requires removal of the c&d changer and uses harness to connect instead. I ordered it. Hope it'll arrive soon. Will post progress report.
Old Aug 19, 2014 | 05:59 AM
Oops, I was reading the description too fast as was travelling and working 20/hr days. Looks to be a Dice unit now that the images load. Hmmmm... did Audiovox give up on Dice or ??? Very interesting and let us know how it works.
Old Aug 19, 2014 | 08:57 AM
Enterpriser's Avatar
Enterpriser is infamous around these parts
Looks like an unbranded DICE unit, if you can take a pic when it arrives and let us know how it works. I have the DICE unit which looks just like that and it NEVER works on first try/starting the car. I have to open glove box and wiggle harness and unplug it until I see the red light inside the DICE then I have to wiggle more. Eventually it works, it just takes about 5 minutes of pushing and prodding. Needless to say I would love to see if this was an updated unit.
Old Aug 19, 2014 | 09:07 AM
Enterpriser,
Sounds like a weird/defective unit. Do you use the DICE unit connected to an iApple device and use said Apple device to change songs, etc? If so, you have only FIVE seconds from the moment you unlock the car until swiping-on the Apple device to get it initiated so as NOT to go into ACCESSORY mode. Hope this helps.
Also, please make sure you have the latest firmware
www.diceelectronics.com/fw-update.php?manuf=Audiovox%20Corporation
ADDED: When you flash the Mediabridge, MAKE SURE you also read the instructions as it WILL announce song names. etc via MAT unless you change the options.
http://audiovox.diceelectronics.com/..._rev062012.pdf
WARNING: Flashing to the new firmware means you WILL need to completely 'reprogram' the unit to your Bluetooth, then after that STAY in Bluetooth and adjust the MAT announcements or else you'll always get song announcement, etc. Yes, it is a PIA to get it done but once done you're all set.
Old Aug 19, 2014 | 09:31 AM
Great information! Yes I have the Dice connected to my iphone and when I turn the car on I go through the nav OK and YES option and I hit CD to switch to the DICE and it doesnt work 99% of the time. So then I grab the wide pinned black harness out of Dice and wiggle it out, then upon reentry of that I hear the speakers kind of pop and then Spotify or Pandora starts playing and I am good to go. I will try to accelerate my process and heed your 5 seconds deal. Thanks again!
Old Aug 19, 2014 | 08:34 PM
Gambit's Avatar
Maaaannn. sounds like a pain in the ***..
I hope my unit won't behave like that. will find out soon enough.
On my old M6: bluetooth didn't support music, only calls, so i bought inexpensive Bluetooth adapter ( about 40$) and pugged into AUX jack, and it worked like a charm… But my lovely Bentley doesn't have AUX. Folr last 4 days I've been listening to CD's!!!! I believe thats what they called.. CD's…. these shiny circular discs that fit 10-12 songs. LOL
Old Aug 22, 2014 | 07:00 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Be thankful that we don't have 8 track cartridge systems any more.
Les.
Old Aug 29, 2014 | 09:12 PM
Gambit's Avatar
Finally got around to hook up the NEO unit. It took me about 10-15 min. Must have proper tools to remove the cd changer. It took few tries to set up bluetooth, but once set up it worked like a charm. Streaming pandora and itunes just fine. Can skip songs etc, but it doesn't show text. I haven't try the hard connection yet but I assume it should work just as well. Great thing about this unit is that it bluetooth only stays connected wile the audio on CD. But when you switch to radio it disengages your iphone bluetooth so if calls or text comes in it actually rings. Overall I like the unit very much.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Aug 21, 2015 06:34 AM
