check engine light
Old Jul 22, 2024 | 08:56 AM
Andycap01's Avatar
Andycap01
Okay perfect. I will do that, i have done a smoke test before on a gt so do have the know how. Just to get a machine again. Anyway i doubt the secondary filters have ever been done. Could that be a cause?
Old Jul 22, 2024 | 09:31 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Worth checking the secondary filters. I removed mine and cleaned with compressed air. I doubt the filters are the issue. For now you may want to do a "readiness test" on your RT scanner. There you can see if the secondary injection is a pass or fail. I don't this problem is affecting performance. The car might not pass an emissions test thought.
Old Jul 22, 2024 | 09:40 AM
Andycap01's Avatar
Andycap01
I also see exhaust temp sensor fault code that be related. Emissions we dont worry in my country
Old Jul 22, 2024 | 10:00 AM
5 Year Member
Not related. This you will want to fix. The exhaust temperature sensor is a safety sensor. When the turbo boost is high and hot the sensor(s) ensure that the exhaust temperature doesn't exceed certain conditions and damage the engine. The exhaust temperature sensor can send the ECU a message to adjust maping accordingly.
Hawkinz69
Bentley
34
Jun 9, 2018 10:27 AM
REKX
Feb 4, 2016 11:56 PM
MBA
Feb 4, 2016 02:23 AM
