Modding plan for my 2004 CGT
Old Aug 4, 2016 | 08:48 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
Hi guys,
Since I've invested quite a bit lately to refurbish my car mechanically, I figure I'll keep this beast for the long haul. While the car looks get looks from people, it looks a bit dated so I'm doing (planning) several mods to rejuvenate it.
1. Refinished my headlights (~$600)(Done):
a)Before: it looks somewhat dated
b)After: added 4 angel rings to match factory headlight colour; painted housing to black; polished the interior lens to get rid of tiny burn marks.
I still need to get the exterior lens refinished to get rid of the stone chips. This mod requires your headlight to be opened using heat gun. My biggest concern is how long will the LED strip last due to high heat from the XENON. It will be costly to repair because the front bumper and fender has to come off to reach the light.
2. Purchased black headlight bezel ring (~$250) (so expensive considering they're aftermarket and just simple plastic)(Done):
3. Update front bumper and rear bumpers to Supersports (~$5600 for used front, back, and the three-piece grill + $2000 - $3000 bodyshop)
This option is very expensive so I'm still debating it. I might just get the front bumper and forgo the rear as the difference isn't very big.
4. Black out front grill, trims, and slightly tint rear light.
This one is straight forward and shouldn't cost too much.
5. Wrap the entire car in 3M 1080 Satin Dark Grey ($2500 - $4000):
I might get the front and back SS bumper, forgo the bodyshop and get it wrapped instead. I'm also tempted to get a crazy color like green but I think I'd be tired of a flashy colour on a Bentley very soon.
6. Install a 360 parking camera system
I've bought the Nav-TV unit to get two video input ($$$) and will investigate on installing a 360 system or at bare minimum, a reverse camera.
The installation entails one rear cam, one front cam, two side cam mounted on each side of the mirror (drilling a hole is required).
7. Repair saggy headliner (not really a mod)
8. Chip the car with GIAC tune
9. Fabspeed Secondary Catbypass X-Pipe
10. Quicksilver Exhaust
Old Aug 5, 2016 | 08:40 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Hi Lilo.
Unless you have already done it, the 1st rule of making any car look better is to change the wheels.
I did that to my 2004 GT by fitting a set of V8S 20" alloys. Much easier to clean too!
Les.
Old Aug 5, 2016 | 10:11 AM
lilo1980's Avatar
Hi Les,
My car has been running on a set of 20" Dark Silver Speed wheels. I've considered getting some 21" but I'll wait until my tire tread runs out.
The winter wheel is the 19" mulliner two-piece. I'm thinking of getting it refinished in Gloss black.
ID:	455345   Click image for larger version
ID:	455346   Click image for larger version
ID:	455347   Click image for larger version
Old Aug 5, 2016 | 11:49 AM
lilo1980's Avatar
Just ordered fabspeed x-pipe.
I found a good deal on a slightly used OEM Supersports front and back bumper for $3700 shipped.
The bumper will come with paint but they don't match with my current colour.
I can either get it painted or wrap the entire car. I think they both cost around the same.
What do you guys think?
Old Aug 8, 2016 | 09:42 PM
lilo1980's Avatar
The lights got put back in the car but I don't have the chance to test them yet since it is still in the shop. Overall, I love how it turned out.
vs
Old Aug 10, 2016 | 09:59 AM
Refresco's Avatar
Refresco is infamous around these parts
Carbon Fiber Interior Trim from a Supersport would finish it off nicely!
Old Aug 12, 2016 | 07:27 PM
lilo1980's Avatar
Thanks Refresco. Your CF kit is a steal!
I got the 360 Camera kit today. I hooked up to the TV and everything works.
Here is the kit:
Head Unit:
Four cameras:
Remote:
Four cam view:
Front view:
I'm investigating the possibility of using some wifi/bluetooth enabled relay so I can use my tablet to do certain things such as activate camera system when speed is under 10 km/hr.
Also, I can integrate Flic bluetooth button to toggle between views.
sosdon
Apr 8, 2016 01:14 PM
tdream1
Mar 30, 2016 10:22 AM
dhope618
Mar 26, 2016 06:59 AM
REDNOSEGT
Bentley
Mar 25, 2016 11:07 AM
Kevin M
Cayenne 955/957
Jul 31, 2003 04:58 AM
