Last attempt to fix rear aerofoil, help required
Old Jan 9, 2019 | 10:17 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Off the schematic diagram above. I would assume it is the switch that is between seats.
Old Jan 9, 2019 | 07:57 PM
5 Year Member
To be clear, the active airfoil switch is a bi-directional switch acting in a sense like a solenoid. Should it be fidgety it can stick in different modes causing the problems described. The motor is stupid, taking directions from the switch.
Look closely at the schematic above. One can see the two different modes of the switch, up or down of the airfoil.
Of course other issues can be at play. One ought to rule this one out or in before proceeding to buy parts.
Old Jan 10, 2019 | 12:27 PM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
Originally Posted by blue_racing
my motor runs but but doesn’t stop goes for about 5 seconds so if connected to spoiler bends all the rods in boot as spoiler is up in about 1 .5 seconds after lifting cover off motor the electronic board in there also lifts out I wish they just sold the board as nothing wrong with rest of motor !
The most common fault is a broken wire in the LHS ( as you stand at the back looking Fwds ).Of the wires around the hinge .
I think you need the Bentley diagnostic computers to tell you which one .
I used the guys at Prestige Service Leeds to fix mine .From memory about £100 mostly labour .They re connected the open circuit .
symptoms were light came on and it did not move ,stayed down .It was intermittent depending on wether the open circuit closed by accident with boot opening .
Before giving up and taking to them ( due a service anyhow ) I did take a look, removed the motor , checked the worm drive and the rods and the plastic things that suppose to snap - all seemed ok .
I dismantled the motor on the kitchen table , when reassembled found the +ve and ground and applied 12 v both ways it turns .
Theres a whole load of pcb inside and it’s Bentley stickered on the outside .
so I fugure the D.C. motor turns both ways for a predetermining time when the spoiler reaches its out limit ( no external sensors ) you will get a temp inc in resistance at it stops , the pcb will detect this and cut the power .Same when it retracts .
This movement time ( up or down ) and subsequent resistance end time to cut the power will be unique to BentleyI guess .
And the VW Beetle .Hence the differences in part no and external sticker .
ok the motor , the housing / mounting are identical ( except label ) but the pcb will be unique to the vehicle because of the different timings for the up / down as they are different spoilers weight / size / shape / range of movements-etc .
I did look like others at the VW part something like £50 as said it was just a broken wire and paid a Bentley tech to fix it .
What we need now is somebody to come along with a live example ( and MY of car ) to say the VW part is plug n play .
btw You can manually pull up and push down the spoiler when it’s not working as there’s no power to the motorand the gears / motor just turn as you move it or push it down .No harm done .
Nice to clean the cr8 p out under it and poke strimner line down the two drains .Theses drains open out under the boot lip .
Old Dec 18, 2019 | 05:38 PM
Raphael's Avatar
Raphael is infamous around these parts
I had the same issue on my 06 GT, was told by Bentley whole motor needed to be changed for 4k£, got it cleaned and repaired by a specialist for £700. Was told issue is over time, system gets dirty, only needs cleaning and repairing of pieces that got damaged
temi
Bentley
10
Feb 5, 2022 11:29 AM
ECS Tuning - BMW
BMW Vendor Classifieds
Feb 10, 2014 10:14 AM
carlosC4S
Bentley
11
Oct 17, 2013 08:30 AM
Nigel1234
Bentley
Dec 30, 2011 05:44 AM
