ECU replacement.
Old May 2, 2019 | 12:35 AM
steve.2.lowe's Avatar
steve.2.lowe is infamous around these parts
ECU replacement.
Hi Guys,
Has anyone replaced the slave engine ECU and how did it go?
Old May 2, 2019 | 01:33 AM
joc44's Avatar
joc44 is infamous around these partsjoc44 is infamous around these parts
You can only replace the ECU's in TWO's, £1,500 each +setup +vat,. I had mine out 6 to 8 times last year only to find i had a broken N75 valve, Easy to get at, but for 4grand Bentley will put them in for free LOL.
Old May 2, 2019 | 01:48 AM
Um, looks like an ECU rebuild could be the way to go!
Old May 2, 2019 | 01:59 AM
joc44's Avatar
Why do you think your slave ECU is faulty
Old May 2, 2019 | 02:02 AM
Got a miss fire on cylinder 8, injector has been changed and wiring checked from ECU to the injector and that's all good.
On looking inside the ECU it looks like it has some historical water damage and it has faulty written on the outside!
The error I'm seeing reported is:
16592 - Injector: Cylinder 8 (N86)
P0208 - 004 - Circuit Malfunction - Intermittent
Old May 2, 2019 | 02:09 AM
joc44's Avatar
I sent mine to here, A T P Electronic Developments Ltd
Cannock Wood Industrial Estate, Cannock Wood Street, Cannock, Staffordshire WS12 0PL
Old May 2, 2019 | 02:11 AM
Happy with the result?
Old May 2, 2019 | 02:17 AM
joc44's Avatar
Yes, told me nothing wrong with them it must be something else and it was (the N75 valve).
Old May 30, 2024 | 08:53 PM
Mansoneyr's Avatar
Mansoneyr is infamous around these parts
I replaced the slave engine ECU on my Audi last year with chiptuning slave tools. It was quite a process, but it went smoothly with some patience. First, make sure you have the exact part number for your replacement ECU. Disconnect the battery before starting to avoid any electrical issues. When installing the new ECU, take your time to securely connect all the wiring harnesses. Once installed, you’ll likely need to reprogram or reflash the ECU to match your vehicle’s specifics. For me, it took a couple of hours, but everything worked perfectly afterward.
captcmk
Bentley
Feb 23, 2024 07:46 AM
saline
Nov 1, 2011 09:29 AM
sandyclinic
993 Turbo
Mar 10, 2010 11:58 PM
StephenTi
Mar 11, 2005 05:41 AM
