LED Instrument panel failure
Old Jul 3, 2019 | 11:15 AM
joc44's Avatar
joc44 is infamous around these partsjoc44 is infamous around these parts
HI all, LED to the side have gone, where do we start. Lol
Old Jul 3, 2019 | 12:26 PM
Rico.Adams's Avatar
5 Year Member
Rico.Adams is infamous around these parts
HI Joc44 ... This is a normal failure and most will fail at some point, Its a LCD screen and can be repaired by these guys, they can repair the whole clock cluster or just the LCD screen, give them a call.
Simple to remove once you pull the face plate off ...
CARTRONICS
Unit 20 The Parkwood Centre Aston Road
Waterlooville
PO7 7HT
Hampshire
Phone: 02392 265986/ 02392 241412
Email: info@cartronix.co.uk
Old Jul 4, 2019 | 04:18 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
CARTRONICS
Waterlooville
PO7 7HT
Hampshire
Good Info Rico!
Old Jul 4, 2019 | 06:34 AM
Rico.Adams's Avatar
5 Year Member
Originally Posted by BWings
Good Info Rico!
How are you Steve hope all is well, enjoy the celebrations ...
Old Jul 4, 2019 | 08:40 AM
BWings's Avatar
5 Year Member
Thank you sir! Yes, we'll enjoy red hot burning sulfur fireworks tonight in 43*C air temps....haha.....
Old Jul 4, 2019 | 09:11 AM
Rico.Adams's Avatar
5 Year Member
WoW sounds fantastic, 23*c here and thats the best we going to get ... Enjoy ...
Old Jul 4, 2019 | 07:37 PM
Samhain's Avatar
Samhain is infamous around these parts
Aren't you going to curse us as treasonous colonists? Who drive British cars?
Old Jul 5, 2019 | 02:05 AM
Rico.Adams's Avatar
5 Year Member
Is the question to me Samhain, if it is why would I want to curse you or anyone ...
People are free to do what they please each life is as presous to each & everyone of us. Live life to the full ...
Old Jul 5, 2019 | 08:56 AM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Sometimes, simply resetting the screen will clear the problem. The simplest method is to disconnect and reconnect the batteries. There are a number of threads on this forum specifying how to deal with batteries.
Old Jul 5, 2019 | 09:33 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
I've encountered a similar problem on a Mercedes. Turned out the backlit light burned out. Pulled the MB dash, referenced the small light and was back in business. Without having pulled the Bentley unit can't say if that's the same. Try Mr. PMS's recommendation or perhaps pull the appropriate fuse.
Since instrument removal will be necessary to repair if all else fails. Worth double-checking if there is an accessible light to change out. The Mercedes bulb was very tiny.
Old Jul 5, 2019 | 09:58 AM
Samhain's Avatar
From a post on the Phaeton site:
There is a way of doing a 'reset' on that display, give it a try, it might solve your problem and avoid you needing to make a trip to the dealer. Here are the instructions:
1) Turn off the ignition, remove the key from the key-hole.
2) Open the big fuse box cover directly below the steering wheel. (See owner manual 3.2 - the last booklet in the folder - page 74 for instructions how to open the cover of the fusebox).
3) Remove fuses 23 and 27.
4) Wait 30 seconds.
5) Re-install the two fuses. They are the same size, so no worries about mixing them up.
6) Close the fuse box cover.
7) Say a prayer or invocation appropriate to your religious beliefs.
8) Turn the ignition switch back on, see if the display works OK now.
If the display works OK after doing this, next time you are at your VW dealer, tell you he owes you 15 minutes of pay for performing a service function under warranty. If this does not fix the problem, then the instrument cluster needs to be replaced. But my guess is that this will fix your problem.
Volkswagen of America technical bulletin C-90-04-01 dated July 16, 2004 explains this process in detail.
Let us know how it goes...
Michael
With the ignition off, pull these two fuses, then wait 30 seconds and re-install them.
my996
Apr 20, 2017 09:45 PM
toddh23
Oct 10, 2008 05:24 PM
911bobby
Aug 6, 2008 02:26 PM
RCH
Feb 13, 2007 12:50 PM
82targa
Sep 30, 2006 09:45 AM
