Trickle charging
Old Aug 1, 2019 | 11:15 AM
JoeRube's Avatar
JoeRube is infamous around these parts
Trickle charging
I have a 2013 GT, and all of a sudden the car wouldn’t start. All electronics work, IE- lights, windows and the rear boot, but the car won’t start or even attempt to turn over at all.
I’m assuming its the batteries and they either need to be charged or replaced?? I’ve had it on the trickle charger for the better part of 2 days and it’s still on “Phase 2”....
my question is is how long should I expect this process to take before the car can be started and also should I have the rear boot open or closed while it’s charging?? Or does it not matter? I have the magnetic connector. Thanks in advance!
Old Aug 1, 2019 | 03:14 PM
MBi's Avatar
MBi
MBi is infamous around these parts
If the battery completely died I would try the recondition option. If that doesn't work get a battery tester as you have two. Did you try starting the car with the second battery or only the normal way?
Old Aug 1, 2019 | 03:18 PM
JoeRube's Avatar
I tried the emergency start with the key, and even jumping the car with my truck. Neither worked. So now I have it on the trickle charger hoping that helps.
From what ive read it sounds like the battery could be highly sulphated. So I went the the process and desulphation and now it’s “charging” or so it says.
Old Aug 1, 2019 | 03:58 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
This information is useful if disconnecting batteries.
File Type: pdf
Old Aug 3, 2019 | 08:28 AM
Rico.Adams's Avatar
5 Year Member
Rico.Adams is infamous around these parts
Hi Guys ... This Snap-On battery tender is one of the best on the market, I got hold of one to borrow and put my AMG (left side) battery on for a few hours and the battery was like new once it went through its cycle ...
dougcayenne
Feb 16, 2019 08:09 AM
John in Norcal
Dec 15, 2015 08:39 AM
ShokWaveRider
Feb 25, 2010 04:58 PM
Griza
Nov 19, 2005 08:33 AM
Hooligan
Aug 16, 2005 07:41 PM
