TPMS compatible sensors
Old Nov 5, 2019 | 06:49 AM
cerex's Avatar
cerex is infamous around these parts
I am getting new tires mounted this week figured I might as well get new TPMS sensors installed.
any suggestions on what to get that will work with our car?
2007 Bentley GT
many thanks
alex
assume there is aftermarket sensors out there at a decent price that are plug and play?
Old Nov 5, 2019 | 05:11 PM
GT3Fan24's Avatar
GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !
Many options to choose from. Yes you can go aftermarket. Also OEM replacement Huf UVS.
Last edited by Johnny Hotspur GT; Jun 30, 2023 at 12:17 PM. Reason: Link / non sponsor advertising eBay store in forum
Old Nov 5, 2019 | 07:21 PM
cerex's Avatar
That’s great thank your for the info
Old Nov 6, 2019 | 02:42 AM
dskippy888's Avatar
dskippy888 is infamous around these parts
I heard some sensors are using 415mhz for earlier years. Does anyone know how to determine what is on our cars?
Old Nov 6, 2019 | 03:12 AM
GT3Fan24's Avatar
His car model and year is 433. I am sure the dealer would tell you. If you give me your yr, make and model I can tell you. I have a TPMS programming tool.
Old Nov 6, 2019 | 03:18 AM
sspeeder's Avatar
sspeeder is infamous around these parts
Try AUTEL programmable sensors. They are quite inexpensive and work very well. I have changed mine 3 years ago and had no issue every since.
Last edited by Johnny Hotspur GT; Jun 30, 2023 at 11:42 AM. Reason: Link / Dead Link
Old Nov 8, 2019 | 01:57 AM
dskippy888's Avatar
To clarify I meant 315mHz vs 433mHz. I have a 2004 CGT. chassis ending 022041. Would be most grateful if you can share what you find on my car!
Old Nov 8, 2019 | 03:36 AM
GT3Fan24's Avatar
433 for yours
Originally Posted by Rico.Adams
Morning D ...
Great you have the TPMS tool, if you don't mind would you give me the correct mHz reading on a 2006 GT ... Thanks ...
433 for yours
Here is the breakdown that I have from the programmer. 9/03 to 5/05 is 433. 01/05 to 12/05 is 315. 06/05 to 12/18 is 433 and 1/10 to 12/11 is 315.
A few years and certain months they were using both. If you fell in these times then you can search your application by vin. Both of you above do not and shows both is 433.
Old Jun 30, 2023 | 03:14 AM
DrGigabit's Avatar
DrGigabit is infamous around these parts
@GT3Fan24 appreciate this is an old thread. mine Nr ends with 028082
could you check the frequency?
Old Jun 30, 2023 | 05:47 AM
GT3Fan24's Avatar
What is your year, make and model.
DrGigabit's Avatar
Bentley Continental GT 2005
Old Jun 30, 2023 | 06:53 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
they changed coding protocol in the mid of 2005 - make sure you will have it programmed according to right date ranges.
above is true for eu models - here i am 100% sure.
no knowledge about nar or uk.
so the best is to call bentley dealer, give them your vin and they will tell you what sensors are ok
Old Jun 30, 2023 | 07:35 AM
GT3Fan24's Avatar
As stated above. 2 different part#'s for that year. Both are 433mhz but you need the correct protocol. If the dealer gives you the OE part # then I can tell you exactly what you need.
Old Jul 3, 2023 | 10:20 AM
DrGigabit's Avatar
@GT3Fan24 here we go
4d0 907 275
Jonhunt
Jan 4, 2019 09:52 AM
Gibbo205
Apr 17, 2018 03:36 AM
steve.2.lowe
Bentley
Nov 4, 2017 03:50 AM
jbenson
Bentley
Dec 13, 2015 03:15 AM
Dadio
May 5, 2014 07:10 PM
