Bentley key not recognised
Old Nov 9, 2019 | 03:46 PM
lalaw5000's Avatar
lalaw5000 is infamous around these parts
I hope all you clever folks can help me with this. About a year ago I had the dealer install a new battery in the key of my wife's 2013 GT. Everything was fine until recently. The car would give a message that it did not recognized the key. If I pressed the lock and unlock button on the key then it worked. and recognized te key. Now suddenly not even pressing te button is working. It just says key not found.
Old Nov 9, 2019 | 05:44 PM
Johnny Hotspur GT's Avatar
Administrator
Hello LaLaw,
How often is the vehicle driven, what is the charge status of the house battery and the starter battery, if the vehicle has been sitting, batteries could be the cause, also a year and a half may be time for a new key fob battery, depending on use.
Johnny
Old Nov 9, 2019 | 06:29 PM
lalaw5000's Avatar
Hello LaLaw,
Johnny
Thanks Johnny. The car is driven about once or twice a week. If we are away more than 1 week it put it on the charger. Does it give a warning about low battery or does it just disconnect like it has?
Old Nov 10, 2019 | 12:37 PM
PMS's Avatar
PMS
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
Are you referring to the House Battery or the key battery? The key in my 2005 warns me with a "Low Key Battery" message. It is important to replace the batteries in BOTH keys when you change them. Low car batteries will generally put a red battery light alert on your speedometer screen.
Old Nov 10, 2019 | 12:54 PM
lalaw5000's Avatar
Thanks. Its the car key. I think they only replaced 1 battery so that may be the problem. Any good videos out there to show me how to replace the batteries?
Old Nov 10, 2019 | 01:19 PM
lalaw5000's Avatar
Got it sorted. Thanks everyone It was the battery. I replaced it and all good!
Old Oct 29, 2021 | 12:06 AM
jking702's Avatar
jking702 is infamous around these parts
Bentley key low battery
Hi. So I’ve just purchased a used 2010 Bentley continental gt. When I got the car the remote worked fine to open doors and use the push start. About 1 week the key stopped working so I changed the battery. After changing the battery the car still said key fob battery low. I then bought another set of batteries of a different brand and the car still says key fob battery low. Does anyone know what might be causing this or how to fix it ?
Old Oct 29, 2021 | 06:11 AM
Samhain's Avatar
Samhain is infamous around these parts
Try putting the key in the ignition and then pressing the buttons on the key.
Old Oct 31, 2021 | 06:48 AM
jking702's Avatar
I tried to put the key in Ignition and press the buttons. Nothing worked. Still says key battery low
Old Oct 31, 2021 | 10:18 AM
tteplitzmd's Avatar
5 Year Member
tteplitzmd is infamous around these parts
If I replace a key fob battery before the warning, would I have to replace the other key batteries at the same time?
Possibly you have to replace the others at the same time if you get the dash warning so that it will reset?
Old Nov 1, 2021 | 07:47 AM
Samhain's Avatar
Doesn't sound right. I think the car just detects a low battery condition in whatever key fob is within range and displays a low battery condition warning. I've replaced different fob batteries at diff times with no issue.
Old Nov 1, 2021 | 07:49 AM
tteplitzmd's Avatar
5 Year Member
Yeah, that's what I thought.
carrera4slakem
Cayenne
Feb 22, 2020 04:45 PM
elite1
Cayenne 955/957
Jan 8, 2014 08:16 PM
pigcorn
Cayenne 955/957
14
Aug 17, 2013 09:03 PM
Voodoo08
Mar 23, 2011 10:12 PM
gregy
Mar 19, 2004 09:09 AM
