Compressor problem
Old Dec 23, 2019 | 06:55 AM
Mike Dean's Avatar
Mike Dean is infamous around these parts
Compressor problem
Morning all
Came out to my Flying spur this morning to find her sitting on the tires. On further inspection the 40amp air suspension compressor fuse had blown. Replaced to fuse and the compressor came back to life but the car is still sitting on its wheels and will not raise to normal.. any pointers greatly appreciated
Mike
Old Dec 23, 2019 | 09:39 AM
Johnny Hotspur GT's Avatar
Administrator
Hello Mike,
You most likely have a leak in one of the struts.
Did either side front or rear recently show any sagging ?
As to the 40 amp fuse blowing, that is because the compressor got overworked by the leak, so before you burn out the compressor, find the leak, you should also replace the compressor relay as it too can get overheated and burnt, and at some point fuse together not allowing the compressor to shut off, then popping the fuse.
Old Jan 1, 2020 | 03:10 AM
Mike Dean's Avatar
Hi Johnny
Thanks for your reply.
The car has shown no signs of leaking. I replaced the fuse and relay, the pump i can hear working but still the car wont raise of the tires..I have a good look around for leaks and can't find any.
Mike
Old Jan 2, 2020 | 01:54 PM
Dr.Oranje's Avatar
Dr.Oranje is infamous around these parts
What year is the car?
Old Jan 2, 2020 | 02:11 PM
Mike Dean's Avatar
2006
Old Jan 2, 2020 | 02:16 PM
Mike Dean's Avatar
The compressor is working fine.. no leaks etc... The car just will not raise back to normal drive position
Old Jan 2, 2020 | 02:24 PM
Mike Dean's Avatar
Having sprayed the struts with soapy water to check for leaks I can confirm they're not leaking
Old Sep 16, 2020 | 06:23 AM
M Adam's Avatar
M Adam is infamous around these parts
Same problem
can you please contact me
pflum
Cayenne
Dec 4, 2016 09:32 AM
ciaka
Cayenne 955/957
Jun 13, 2015 04:57 PM
mtnrat
Cayenne
Oct 19, 2012 09:29 PM
vanhogh
Mar 8, 2012 09:02 PM
