Rear sub distortion
Old Apr 2, 2020 | 05:44 PM
Jacko Andrews's Avatar
Jacko Andrews is infamous around these parts
Rear sub distortion
Hey all,
I've just had a noise start from the left rear sub speaker on my 2012 Conti GT. On any music, no matter the volume (even if turned to the very minimum) there is a noticeable distortion or rattle from the back corner of the car. It sounds almost as if its loose or some trim has come ajar or something. It cant be a blown speaker, as the distortion is there no matter the volume. It sounds more like an amplifier distortion or something. The only way to stop it is to completely hipass the bass using the tone EQ (its a Naim system).
Anyone come across this before?
Old Apr 2, 2020 | 06:03 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
Either an amp issue, or as you suggested, something simple has become loose. If you can access the wiring to the speaker, then disconnect and reconnect to a known good one, that will narrow things down.
Old Apr 3, 2020 | 07:51 AM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Hello all.
So even at minimum volume it still has the distortion? There are a few symptoms of a blown speaker. Voice coils are tricky. Some take higher volume then others to hear. Balance it left to right, and try to get in the back seat and put your ear as close as you can to pin point it. My bet would be the speaker, seeing that it’s 8 yrs old. Try unplugging it like AJ advised. Might be a little less bass but you won’t have that rattle.
Heck if you have the Ross Tech software it should tell you. When I ran it on mines it told me my left front mid had a short in it. I recently changed all my speakers out and my left front mid wasn’t even hooked up. The previous owner had a lot of custom work done (In all honesty it was a freaking hack job) and they basically messed a lot of things up that I had to go in and repair.
ArtB
May 7, 2019 08:29 AM
hollywood996tts
Oct 3, 2016 07:53 AM
gnat
Cayenne 958
Apr 21, 2013 08:30 PM
carendt242
May 12, 2010 10:27 AM
JSV_911
Jan 29, 2008 08:13 AM
