TPMS fault, and remote key short distant
Hello, My car some times it pop up the error TPMS fault... I did replace all TPMS sensor but the problem same.
Here is the fault code
and My key remote can control in very short distant randomly..
which is weirg.. sometimes u can remote to lock and unlock the door very far.. but some times very short...
is this antena issue?
thank you
Thursday,09,July,2020,18:20:43:47143
VCDS Version: Release 20.4.1 (x64) Running on Windows 7 x64
www.Ross-Tech.com
Address 65: Tire Pressure Labels: Redir Fail!
Control Module Part Number: 3W7 907 273 A HW: 3W7 907 273 A
Component and/or Version: J0502 RDK 0004
Software Coding: 0000E05286FD8686FDA7DA00A7DA00
Work Shop Code: WSC 00083 790 00000
VCID: BE30BFC9EDCF1276B9-80EA
1 Fault Found:
02807 - Radio Interference
000 - - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 93602 km
Time Indication: 0
Date: 2000.11.20
Time: 19:42:27
Freeze Frame:
(no units): 87.0
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 93602 km
Time Indication: 0
Date: 2000.11.20
Time: 19:42:27
Freeze Frame:
(no units): 87.0
thank you
i have 2 fobs they all the same problem
and I wonder where is the antenna to get the signal on this car?
Mofongo
May 2, 2015 08:05 AM
