TPMS cant learn...
TPMS cant learn...
Hi,
I switched from my 20" wheels to the OEM 19", and I got fault message after about 30 min learning and it was only showing the front right and rear right sensors... I tried learning several times, but with no luck... Ok so I figured that both left sensors was bad/flat battery. I took 2 of the sensors from my 20" that was working and moved to my 19" wheels. I still cant get the display to show the left sensors... I have tried at least 3x30 minutes, but with no luck. Any suggestions? I have tried both summer and winter settings... About 36 psi front and 44 psi rear.
My 20" sensors that was working, was blue and was called I-Sensor or something like that. All are 434 mhz. So my left sensors are the non-oem blue sensors and the right hand side, are the oem grey sensors. Could it be that all 4 sensors must be the same brand?
I have to drive about 30 km/t for the learn process to start. The way you suggest is key On, no start, dropping pressure for all wheels to what pressure? When key still on, raise pressure to suggested pressures by Porsche?
Sorry if I am slow, but never heard of that method before..
Basically yes but it is supposed to be running.
From a tpms site
2006-2009 Porsche 911; 2006-2008 Porsche Boxster; 2006-2008 Porsche Cayman TPMS Relearn Procedures
1) Put vehicle into relearn mode.
2) With the engine running, deflate each sensor/tire 5-8psi.
3) Reinflate to the door placard specifications.
4) Drive for 30mins.
From a tpms site
Update: Finally the package with the sensors arrived. Well, it was only one sensor instead of 4, and it was dirty and propably used... Fast forward, I ended up using my sensors from my other set and it calibrated in 5-6 minutes of cruising at about 50 mph. All well now
same issue
Hi,
I wasn't expecting that I am gonna find your post. Because I was searching for the https://calbizjournal.com/how-teache...with-diabetes/ site online where I found a topic on how teachers can help students with diabetes. I want to read it and that is why I was searching for it online.
Schpee007
Wheels/Tires
Dec 13, 2014 08:45 AM
