Air Conditioning Recharge
Old Jul 20, 2020 | 06:56 AM
kongolo's Avatar
5 Year Member
kongolo is infamous around these parts
Is it ok to have a Bentley GT's air conditioning recharged at the likes of Kwik-Fit or does it need to be done by a Bentley dealer/specialist?
Old Jul 20, 2020 | 12:47 PM
LarrysFlyingSpur's Avatar
LarrysFlyingSpur is infamous around these parts
I recently had mine charged up by a 'specialist', was blowing only cooler air. I think they've overcharged it. On the quick fit tool i think you're referring to there's a gauge with low / full / take it in for servicing specs. I fitted the connector on the low side to get the reading, very easy, just under the scuttle panel on the left side. Next time I'll try it myself, little risk, can always go back to the specialist and give them some money! i think the system is capable of blowing very cold air.
interested in other replies...
-Larry
Old Jul 20, 2020 | 01:24 PM
British's Avatar
Gone, But Not Forgotten.
British has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud of
I thank the heavens every time I get in my '05 GT that it blows ice-cold air. So yes, the car is capable of true air conditioning.
Old Jul 20, 2020 | 03:46 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
Personally, I wouldnt take my car to Kwik-Fit for anything. Be warned.
Old Jul 21, 2020 | 08:23 AM
Samhain's Avatar
Samhain is infamous around these parts
Yeah you could freeze meat in my car.
Old Jul 21, 2020 | 09:45 AM
TIL that Kwik- Fit is a chain of car servicing centres in the United Kingdom & not a connector on the top of a an AC recharging can!
this is the dial gauge i was referring to....simply attach to your low pressure AC line & see what it says. with the can attached the trigger pull adds freon, with the can detached the freon is sent to the ozone. naturally you have to be aware discharging freon carelessly.
Old Jul 22, 2020 | 07:27 AM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Make sure you have the air on the lowest setting (64-65 I think that’s the lowest setting) air on high and on inside recirc when checking/adding refrigerate.
Old Jul 22, 2020 | 07:34 AM
kongolo's Avatar
5 Year Member
Thanks for the advice! Have decided against taking it to Kwik-Fit and have booked it in with a local specialist in Kent (UK).
Old Jul 22, 2020 | 09:01 AM
Well i'm still getting no cooling despite the charge reading to be in the 'full' range. prior to me discharging some freon the needle was in the red. on my very first charge adjustment the system temporarily put out the coldest air but has reverted back to no cooling. so i'm gonna scan for any error codes...
-Larry
(sorry to hijack the original thread topic!)
Dubaitechie
Bentley
51
Mar 21, 2025 09:03 PM
cduluk1
Bentley
May 19, 2017 10:14 AM
awchristler
Bentley
Feb 4, 2015 01:25 PM
