3rd Brake light 2008 Bentley Continental GTC replacement
Old 10-01-2020, 12:19 PM
bradleydetroit's Avatar
bradleydetroit is an unknown quantity at this point
Hello Team, I have a 2008 Bentley Continental GTC. One side of the led on the 3rd brake light is not working. How do I remove this light and replace? Can I do this by going through the trunk?
Old 10-02-2020, 06:12 AM
British's Avatar
Gone, But Not Forgotten.
British has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud ofBritish has much to be proud of
There's a whole thread on here about how to replace the light, unfortunately, it's for the non-convertible, but it might be useful to you. Do a search.
It's generally water infiltration, but I've never heard of half working/half not working.
Old 10-03-2020, 03:51 PM
AJ1's Avatar
AJ1
AJ1 is offline
AJ1 will become famous soon enough
The same thing happened on my last '08 convertible. Luckily it was still under the dealer warranty and they replaced the whole strip, along with lots of seals and gasket kits. Not an easy diy job for most.
Old 10-05-2020, 04:11 PM
Thank you for replying. Yeah that is what I am gathering from the LIMITED information I was able to get.
On a side note. Do you know where I can get a PDF Owners manual for this year and make?
Old 10-05-2020, 04:18 PM
AJ1's Avatar
AJ1
AJ1 is offline
.... I seem to remember someone on here has it, you'll have to search back. He'll send you it free via email (top fella).
Old 10-05-2020, 04:20 PM
AJ1's Avatar
AJ1
AJ1 is offline
Old 12-01-2020, 12:47 PM
Hayssam's Avatar
Registered PM
Hayssam is an unknown quantity at this point
Hi there Bradley have you found a way to remove the light for replacement im facing the same issue
Old 12-03-2020, 06:35 AM
On going......
Currently I still have not found any diy solution for this. I have a trusted mechanic who has advised this is not an easy job on a convertible as it involves going through the convertible top to remove. Then there a a few gaskets and what not to be replaced.
This is probably why there is nothing online in regards to this. At least not what I have been able to find. I may just bite the bullet and have it replaced.
I will I’ll keep digging for now and post if I come across.
Old 07-08-2021, 10:50 PM
fjbarbella's Avatar
fjbarbella is an unknown quantity at this point
The changing of the 3rd brake light is not difficult. It is caused by moisture that comes in from a bad seal...
Use the roof up button....and stop the apron when it is standing up
Under the apron there is a felt skirt that needs to come off. Gently remove the snap buttons and don't break them, you will need to reuse them. Once you take off the skirt you will than be able to remove the 3rd brake light. It has hex screws and nuts that need to loosen and remove.
Note: you will notice that the felt skirt will feel moist, which is an indication that water is getting in and the culprit behind the light not working.
Once all of the screws and nuts are out you can gentle remove the light. There is also sealent tape that might be needed to be replaced.
DuaneLyons
Site News & Feedback
06-19-2018 01:05 AM
rdzulu1
New Member Introductions
11-18-2016 10:58 AM
Quick Reply: 3rd Brake light 2008 Bentley Continental GTC replacement
