2009 Bentley Continental GTC intermittent headlight
Old Oct 26, 2020 | 01:23 AM
Nickricks7100's Avatar
Nickricks7100 is infamous around these parts
Hello everyone,
I am having trouble with a 2009 Bentley Continental GTC
The passenger headlight (outer light) seems to be kind of intermittent as in when I start the vehicle the passenger headlight will be illuminated for only a few moments before dying out then illuminating again the process repeats probably 3 times before totally giving out however if I was to manually turn off the headlamps then turn them back on the process will again repeat.
any help will be greatly appreciated as I am looking for any alternative to removing the bumper and fender however I feel as it will need to happen please help. Thank you all in advance.
i also forgot to mention that I am getting a message in the display that says “Please Check Lights”
Old Oct 27, 2020 | 11:32 AM
ret09gt's Avatar
5 Year Member
ret09gt is infamous around these parts
I have an 09 and mine did the same thing. It ended up being the bulb.
Old Oct 27, 2020 | 09:52 PM
so your recommendation will be to remove the bumper and fender? Thanks for the response.
Old Oct 28, 2020 | 10:58 AM
ret09gt's Avatar
5 Year Member
The passenger side is harder than the drivers but can be done without removing the bumper. You must remove the water tank and fish your hand in there.
Old Oct 31, 2020 | 01:02 PM
I apologize for all the questions but what bulbs did you go with as there’s quite a few options. Best regards.
Old Nov 1, 2020 | 08:48 AM
ret09gt's Avatar
5 Year Member
I went to Audi and got a D2S bulb. You can find a D2S bulb at auto zone.
Old Nov 16, 2020 | 06:06 PM
I apologize terribly for all the questions, did the D2S bulbs send a error message to your dash? Best regards let me know when possible thanks.
Old Nov 17, 2020 | 07:38 AM
ret09gt's Avatar
5 Year Member
No error because d2s bulb is oem.
tonygt63
Bentley
24
Dec 17, 2020 01:32 PM
Nickricks7100
Bentley
Oct 26, 2020 01:12 AM
rdsrllc
Bentley
14
Jul 23, 2020 11:03 AM
Rommanager
Bentley
Apr 17, 2020 02:27 PM
cduluk
Bentley
Oct 8, 2008 11:22 PM
