ACC Fault
Old Dec 3, 2020 | 01:38 PM
Realdeal12's Avatar
Realdeal12 is infamous around these parts
ACC Fault
Hello,
I am receiving and ACC Fault for my 2011 Flying Spur speed also I'm getting a rear turn signal bulb fault. I was wondering if anyone had any ideas on what I need to correct this part? I'm going to attach my vag reading.
Code:
 Thursday,03,December,2020,14:29:18:14311
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: SCBBP9ZA7BC067008 License Plate: 12-3
Mileage: 81430km-50598mi Repair Order:
Chassis Type: ZA (6N0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 19 1F 23 28 34 36
37 38 46 47 53 65 66 68 6C 71 76 77
VIN: SCBBP9ZA7BC067008 Mileage: 81430km-50598miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 1010
06-Seat Mem. Pass -- Status: Sporadic communication error 1000
07-Control Head -- Status: Malfunction 1010
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1F-Sat. Tuner -- Status: Malfunction 1010
23-Brake Booster -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Sporadic communication error 1000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Malfunction 1010
53-Parking Brake -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 1010
65-Tire Pressure -- Status: Malfunction 0010
66-Seat, Rear -- Status: OK 0000
68-Wiper Electr. -- Status: Malfunction 1010
6C-Back-up Cam. -- Status: Malfunction 1010
71-Battery Charger -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 1010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine ( ) Labels: None
Part No SW: 07C 906 018 HT HW: 07C 906 018 HE
Component: BY - 6.0 L - TT A ª7780
Revision: --H06--- Serial number: VWX3Z0J7917405
Coding: 0021170
Shop #: WSC 00083 790 00000
VCID: 7EF33BE52AC0927661-5122
7 Faults Found:
005717 - Please check DTC Memory of Auto. Distance Controller
P1655 - 004 -
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 81299 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 021
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 64.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.938 V
005644 - Coolant Pump 2
P160C - 004 - Open circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 81299 km
Time Indication: 0
Freeze Frame:
RPM: 134 /min
Load: 59.2 %
Speed: 0.0 km/h
Temperature: 5.0°C
Temperature: 6.0°C
Voltage: 10.287 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 81299 km
Time Indication: 0
Freeze Frame:
RPM: 164 /min
Load: 60.4 %
Speed: 0.0 km/h
Temperature: 5.0°C
Temperature: 6.0°C
Voltage: 10.414 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 004 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 81299 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 64.0°C
Voltage: 11.938 V
006436 - Controller Pin Coding
P1924 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 000
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 64.0°C
Voltage: 11.938 V
001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0544 - 002 - Circuit Malfunction
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 81372 km
Time Indication: 0
Freeze Frame:
RPM: 811 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 11.0°C
Voltage: 11.684 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 81436 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 020
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 57.0°C
Voltage: 12.192 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 AP HW: GS1 911 4
Component: ZVBC3624 6L W12TT 3624
Revision: --H05--- Serial number: 0136788
Coding: 0000111
No fault code found.
Address 03: ABS Brakes Labels: 3W0-614-511.clb
Part No SW: 3W0 614 511 H HW: 3W0 614 511 H
Component: ESP 8.1 4WD H01 0650
Revision: 00000000 Serial number: 00000000000000
Coding: 0002321
VCID: 3467D9CD530C8826C7-8060
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 18
Reset counter: 34
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0023
Hex Value: 0x01A8
Hex Value: 0x0000
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 G HW: 3D0 909 137 G
Component: 7E Kessy 6850
Revision: 00H22072 Serial number: VWX3Z0J7917405
Coding: 0405741
VCID: 2B55C2B18E32D7DE96-807E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 5
Time Indication: 0
Date: 2020.08.22
Time: 12:57:14
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 14
Reset counter: 107
Time Indication: 0
Date: 2020.10.26
Time: 17:06:18
00087 - Terminal 30 for Starting Relevant Consumers
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 107
Time Indication: 0
Date: 2020.10.26
Time: 17:06:18
00184 - Control Circuit for Engine Start/Stop Switch
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 81
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 CA
Component: Sitzmemory D1 BF 1743
Coding: 0000003
VCID: 77FD2EC102FAA33E22-8022
1 Fault Found:
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008 J
Component: ZAB COCKPIT 2270
Coding: 0573327
VCID: 3467D9CD540C8826C7-5122
6 Faults Found:
00385 - Positive Output Audio Channel for Speech/Telephone
012 - Electrical Fault in Circuit - Intermittent
00386 - Negative Output Audio Channel for Speech/Telephone
00856 - Radio Antenna
00823 - Line-Output; Front Left
00859 - Line-Output; Front Right
Address 08: Auto HVAC Labels: None
Part No: 3W5 907 040 G
Component: Climatronic BY611 2027
Coding: 0000112
Shop #: WSC 00000 000 00000
VCID: 3A7BF7F571687E561D-806E
1 Fault Found:
00032 - Rear Right Defrost Button (E300)
006 - Short to Plus - Intermittent
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 N HW: 3D0 937 049 N
Component: J519 6900
Revision: -4005--- Serial number: --------------
Coding: 40020000AB2A11000000000000000000
VCID: 3561E4C95876912EF0-8060
2 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
011 - Open Circuit - Intermittent
01505 - Bulb for Blinkers; Rear Right (M8)
Address 11: Engine II Labels: None
Coding: 0021170
VCID: 7EF33BE52AC0927661-5104
2 Faults Found:
012425 - Signal Line for Fuel Pump Electronics
P3089 - 004 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 80857 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 022
RPM: 151 /min
Load: 49.0 %
Speed: 0.0 km/h
Temperature: 67.0°C
Temperature: 39.0°C
Voltage: 10.287 V
001672 - ECM Power Relay Load Circuit
P0688 - 002 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 80916 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 143.0°C
Temperature: 27.0°C
Absolute Pres.: 990.0 mbar
Voltage: 0.000 V
Address 13: Auto Dist. Reg Labels: None
Part No SW: 3W0 907 567 A HW: 3W0 907 567 A
Component: AC201 NAR BY611 00871
Revision: 00031000 Serial number: 00000000054632
Coding: 0020611
VCID: 3D71FCE96046496E38-8068
1 Fault Found:
00272 - Function Disabled due to Electromagnetic Interference
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 7
Fault Frequency: 1
Reset counter: 174
Mileage: 81436 km
Time Indication: 0
Date: 2001.04.19
Time: 14:21:21
Freeze Frame:
Count: 48
Address 15: Airbags Labels: None
Part No SW: 3W8 909 601 HW: 3W8 909 601
Component: 18 Airbag 9.41 H14 0040
Revision: 91H14004 Serial number: 0039L000FJF$
Coding: 0012600
VCID: 7BF532F13ED2875E46-802E
Subsystem 1 - Part No: 3W5 959 339
Component: BF-Gewichtsens. H02 0003
Subsystem 2 - Serial number: 00SEP
Subsystem 3 - Serial number: 63328RB4056DEDA7
Subsystem 4 - Serial number: 63428RB4057287C7
Subsystem 5 - Serial number: 63528RB405728836
Subsystem 6 - Serial number: 63628RB40572881D
Subsystem 7 - Serial number: 63700RB4
Subsystem 8 - Serial number: 63800RB4
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 211
Mileage: 80707 km
Time Indication: 0
Date: 2020.09.30
Time: 18:48:35
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000042
VCID: 479D9E01329A13BE92-8012
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No SW: 3W0 920 841 M HW: 3W0 920 841 M
Component: J285 KOMBI-INST. 2226
Revision: K0H10V44
Coding: 0007202
VCID: 3F8D86E16E4A5B7E2A-806A
14 Faults Found:
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 80941 km
Time Indication: 0
Date: 2020.11.16
Time: 10:21:38
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
00457 - Central Electronics Control Module / BCM (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
00459 - Control Module for Display and Input; Front (J523)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3W0 920 841 M
Component: J533 GW-K-CAN TP20 2226
Coding: DFFBFF7E97071702
VCID: 70EF15DD6394F406E3-8024
19 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 80941 km
Time Indication: 0
Date: 2020.11.16
Time: 10:21:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80920 km
Time Indication: 0
Date: 2020.11.13
Time: 19:23:32
02649 - Digital Radio Tuner
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 194
Mileage: 80920 km
Time Indication: 0
Date: 2020.11.13
Time: 19:23:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Address 1F: Sat. Tuner
Cannot be reached
Address 23: Brake Booster Labels: None
Part No: 3W0 907 563 B
Component: BREMSBOOSTER 007 0430
Revision: 00007000 Serial number: 00000000015478
Address 28: HVAC, Rear Labels: None
Part No: 3W5 907 049 A
Component: Rear HVAC Head Unit 0004
Address 34: Level Control Labels: 3Wx-907-553-34.clb
Part No: 3W5 907 553 D
Component: LUFTFDR.-CDC- 3C3V0 7041
Coding: 0005531
VCID: 408F851D17B4248653-8014
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 CA
Component: Sitzmemory D1 F 1737
Coding: 0000004
VCID: 6FED16A17AAAEBFEFA-803A
1 Fault Found:
Address 37: Navigation Labels: None
Part No: 3W0 919 887 Q
Component: NAVIGATION 2222
Coding: 0400000
VCID: 55A14449F836B12E10-8000
1 Fault Found:
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 F
Component: Dachmodul 0802
Coding: 0004141
VCID: 3979E8F9746E754E14-806C
2 Faults Found:
00926 - Terminal 30
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 H
Component: 35 HSG 0200
Coding: 0000040
VCID: 3561E4C95F76912EF0-4B02
Subsystem 1 - Part No: 3W5 959 701 F
Component: Tuersteuergeraet FS 1003
Subsystem 2 - Part No: 3W5 959 702 F
Component: Tuersteuergeraet BF 1003
Subsystem 3 - Part No: 3W5 959 703 C
Component: Tuersteuergeraet HL 1003
Subsystem 4 - Part No: 3W5 959 704 C
Component: Tuersteuergeraet HR 1003
Subsystem 5 - Part No: 3W0 909 610 G
Component: 11 HDSG 1810
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
7 Faults Found:
01699 - Motor for Central Locking; Hatch/Trunk (V53)
00319 - Rear Lid Hydraulic Motor (V241)
Address 47: Sound System Labels: None
Part No: 3W5 035 465
Component: 08K-AUDIOVERST 1000
VCID: 76E323C505F0DA3639-8022
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 F HW: 3W0 907 801 F
Component: EPB BC7H0280 HC7 0280
Coding: 0022413
VCID: 3979E8F9736E754E14-5122
1 Fault Found:
02443 - Control Head
Address 65: Tire Pressure Labels: Redir Fail!
Part No SW: 3W7 907 273 A HW: 3W7 907 273 A
Component: J0502 RDK 0004
Revision: 0004 004 Serial number: 00000700008148
Coding: 0000E05286FD8686FDA7DA00A7DA00
VCID: 3E73FBE56D40527621-806A
2 Faults Found:
01840 - Antennas for Tire Pressure Monitoring
005 - No or Incorrect Basic Setting / Adaptation - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100101
Fault Priority: 3
Fault Frequency: 3
Reset counter: 194
Time Indication: 0
Freeze Frame:
(no units): 177.0
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 213
Mileage: 81402 km
Time Indication: 0
Date: 2001.04.19
Time: 10:46:53
Freeze Frame:
(no units): 63.0
Address 66: Seat, Rear Labels: None
Part No: 3D0 959 860 CA
Component: Sitzmemory D1 H 1702
Coding: 0000001
VCID: 70EF15DD6794F406E3-8024
1 Fault Found:
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W5 955 023 H
Component: Wischermodul ª8328
Shop #: WSC 00000 725 65552
VCID: 3F8D86E16A4A5B7E2A-806A
5 Faults Found:
01308 - Control Module for Roof Electronics (J528)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3W5 907 441 HW: 3W5 907 441
Component: J772__Rearview 0023
Revision: 00H14000 Serial number: PA8 J040080
Coding: 2000003
VCID: 78FF2DFD0FE4AC462B-802C
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 45
Reset counter: 210
Mileage: 80857 km
Time Indication: 0
Date: 2020.10.21
Time: 13:50:29
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 209
Mileage: 80857 km
Time Indication: 0
Date: 2020.10.26
Time: 17:10:17
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 2447298DE3EC18A657-8070
Address 76: Park Assist Labels: Redir Fail!
Part No SW: 3W0 919 283 D HW: 3W0 919 283 D
Component: J446 ST Parkhilfe 0094
Revision: 11H04001 Serial number: 90031004703973
Coding: 0101016
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 AT HW: 3W0 035 385 AT
Component: rSAP Bentley 0264
Revision: 00008000 Serial number: 31000000153000
Coding: 0031000
Shop #: WSC 00083 790 00166
VCID: 071D5E01721AD3BE52-8052
End-------------------------(Elapsed Time: 05:25)--------------------------
Last edited by Johnny Hotspur GT; Jan 26, 2021 at 06:35 PM. Reason: Put scan in box
Old Dec 3, 2020 | 04:11 PM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
Flat battery the LHS .
Check that first .
Did you hook it up to a charger while scanning it ?
Old Dec 3, 2020 | 05:01 PM
Realdeal12's Avatar
No I didn't. I replaced both batteries and checked the connection and everything appeared to be in contact.
Old Dec 4, 2020 | 11:46 AM
nguyennhatquang's Avatar
nguyennhatquang has a spectacular aura aboutnguyennhatquang has a spectacular aura about
try to clear all the fault code and check the module distance regulation and brake booster
Old Dec 4, 2020 | 12:39 PM
Realdeal12's Avatar
Thank you and that worked. I cleared the fault code in the brake booster as well as the auto distance regulator and now the ACC is working perfectly.
Now my next question is how to I fix the turn signal faults? I'm getting the 01501 and 01505 fault codes?
Old Dec 4, 2020 | 06:16 PM
u need to solder new led bulbs in the turn signal board
Old Dec 5, 2020 | 11:56 AM
Realdeal12's Avatar
Or should I just replace both tail lights?
Old Dec 5, 2020 | 07:44 PM
that will be alot easier but very expensive
Old Jan 26, 2021 | 01:09 PM
Realdeal12's Avatar
I just thought I’d update everyone, I replaced the tail lights and I’m still getting the fault codes. I cleared the codes and the turn signals work perfect. Is there a way to bypass the system so the light in the guages doesn’t show up?
Old Jan 26, 2021 | 01:51 PM
You need LED bulbs with built in resistors which fool the control units into thinking they are normal .
They are available , the “no dash light “ versions .
Old Jan 26, 2021 | 01:55 PM
Realdeal12's Avatar
Where would you go about getting them?
Old Jan 26, 2021 | 02:23 PM
Johnny Hotspur GT's Avatar
Administrator
I am confused, why would you need to "fool" the system, you replaced both taillights correct, and you installed factory tail lights, not some aftermarket light of some kind, right ?
Johnny
Old Jan 26, 2021 | 02:29 PM
Realdeal12's Avatar
Correct, they are the one lights purchased from Bentley.
Old Jan 26, 2021 | 06:04 PM
Administrator
Then you would not need to add anything to fool the system, you need to find the issue causing the error message.
Please post some pictures if you would showing each of the tail light components lit one at a time, then all together, this will help all to see if there is an issue you are missing, so first just parking lights, brake lights, turn signals, hazards, and fog lights, then every thing all together like I did here with my A8L W12 new tail lights, turned out to be a corroded pin connector.
Also if you clear any faults, when does the message come about, when you hit the brake, use turn signal, turn on the parking lights, or fogs ?
Johnny
Old Jan 26, 2021 | 06:14 PM
Administrator
Test
Code:
www.Ross-Tech.com
Coding: 0021170
7 Faults Found:
P1655 - 004 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 81299 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 64.0°C
Voltage: 11.938 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 81299 km
Time Indication: 0
Freeze Frame:
RPM: 134 /min
Load: 59.2 %
Speed: 0.0 km/h
Temperature: 5.0°C
Temperature: 6.0°C
Voltage: 10.287 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 81299 km
Time Indication: 0
Freeze Frame:
RPM: 164 /min
Load: 60.4 %
Speed: 0.0 km/h
Temperature: 5.0°C
Temperature: 6.0°C
Voltage: 10.414 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 81299 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 64.0°C
Voltage: 11.938 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 64.0°C
Voltage: 11.938 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 81372 km
Time Indication: 0
Freeze Frame:
RPM: 811 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 11.0°C
Voltage: 11.684 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 81436 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 57.0°C
Voltage: 12.192 V
Coding: 0000111
Coding: 0002321
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 18
Reset counter: 34
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0023
Hex Value: 0x01A8
Hex Value: 0x0000
Coding: 0405741
Component: ELV XXXX
4 Faults Found:
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 5
Time Indication: 0
Date: 2020.08.22
Time: 12:57:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 107
Time Indication: 0
Date: 2020.10.26
Time: 17:06:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 107
Time Indication: 0
Date: 2020.10.26
Time: 17:06:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 81
Time Indication: 0
Date: 2064.00.00
Time: 00:00:14
Coding: 0000003
1 Fault Found:
Coding: 0573327
6 Faults Found:
Coding: 0000112
1 Fault Found:
2 Faults Found:
Coding: 0021170
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 80857 km
Time Indication: 0
Freeze Frame:
RPM: 151 /min
Load: 49.0 %
Speed: 0.0 km/h
Temperature: 67.0°C
Temperature: 39.0°C
Voltage: 10.287 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 80916 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 27.0°C
Voltage: 0.000 V
Coding: 0020611
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 174
Mileage: 81436 km
Time Indication: 0
Date: 2001.04.19
Time: 14:21:21
Freeze Frame:
Count: 48
Coding: 0012600
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 211
Mileage: 80707 km
Time Indication: 0
Date: 2020.09.30
Time: 18:48:35
Coding: 0000042
Revision: K0H10V44
Coding: 0007202
14 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 80941 km
Time Indication: 0
Date: 2020.11.16
Time: 10:21:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
19 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 80941 km
Time Indication: 0
Date: 2020.11.16
Time: 10:21:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 195
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80932 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 80920 km
Time Indication: 0
Date: 2020.11.13
Time: 19:23:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 194
Mileage: 80920 km
Time Indication: 0
Date: 2020.11.13
Time: 19:23:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 194
Mileage: 80916 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:05
Cannot be reached
Coding: 0005531
Coding: 0000004
1 Fault Found:
Coding: 0400000
1 Fault Found:
Coding: 0004141
2 Faults Found:
00926 - Terminal 30
Coding: 0000040
7 Faults Found:
Coding: 0022413
1 Fault Found:
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 194
Time Indication: 0
Freeze Frame:
(no units): 177.0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 213
Mileage: 81402 km
Time Indication: 0
Date: 2001.04.19
Time: 10:46:53
Freeze Frame:
(no units): 63.0
Coding: 0000001
1 Fault Found:
5 Faults Found:
Coding: 2000003
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 45
Reset counter: 210
Mileage: 80857 km
Time Indication: 0
Date: 2020.10.21
Time: 13:50:29
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 209
Mileage: 80857 km
Time Indication: 0
Date: 2020.10.26
Time: 17:10:17
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Coding: 0101016
Coding: 0031000
c0ke
Bentley
43
May 11, 2024 05:44 PM
jc_333
Bentley
Mar 25, 2023 05:06 PM
Mishanya
Bentley
Jun 8, 2019 10:30 AM
robermj1
Bentley
Feb 16, 2017 11:22 AM
JeremyW
Cayenne 955/957
Jan 3, 2017 06:04 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
