Bentayga W12 Engine Oil spec?
Old Aug 12, 2021 | 11:57 PM
Jero_b's Avatar
Jero_b is infamous around these parts
Hi. I live in a market without a Bentley dealer which up until now hasn't been an issue. The owner's manual is in Russian and I need to find out the oil spec for a 2018 Bentayga W12. I've already purchased the correct filter (would have saved a lot if I didn't search for the Bentley issued version. That's a note for next time). I believe Mobil 1 is recommended. Any help much appreciated. Can't find anything concrete online about the engine oil spec.
Old Aug 15, 2021 | 09:55 AM
nguyennhatquang's Avatar
nguyennhatquang has a spectacular aura aboutnguyennhatquang has a spectacular aura about
the spec is 0w40 from mobil 1
don t buy castrol because the way they weight will be different
for me in summer I ran 10w60
Old Aug 16, 2021 | 08:34 AM
Jero_b's Avatar
thanks. I emailed Bentley and they sent me a copy of the owner’s manual in English. It says you should use Mobil 1 ESP 0W-40 or warranty may be voided. Well I don’t have a warranty anyway so can I use Mobil 1 Ultimate All round Performance 0W-40? The ESP stuff isn’t available where I am.
Old Aug 16, 2021 | 09:14 AM
CatmanV2's Avatar
5 Year Member
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
As long as the numbers match I really can't see a problem with that
C
Old Aug 16, 2021 | 10:01 AM
Jero_b's Avatar
C
i thought as much.
Old Aug 16, 2021 | 10:43 AM
Zaos's Avatar
Zaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond reputeZaos has a reputation beyond repute
There is an actual label of recommended oil 0-40W mounted on top of the radiator for those who does not know
Old Aug 16, 2021 | 11:34 AM
Jero_b's Avatar
Thanks. I’m not where the car is right now only my fiancé is. I’ve asked her a couple of times to pop the hood and check but in the end I gave up. I want to buy the oil first in the main city before heading to where the car is located.
I think I’m quite comfortable with using Mobil 1 0w-40 ultimate all round performance based on the idea that it can’t be that different to the ESP stuff.
Thanks for all the replies. Feedback still welcome of course
Old Aug 16, 2021 | 01:38 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
On a side note ESP= exhaust system protection. ESP formulated oil is further refined and has less sulfated ash, phosphorus and sulphur This type of oil is necessary to protect the catalytic converters. The newer catalytic converters are more refined than earlier versions. So in the long run ESP formulation for the newest Bentleys is required.
Old Aug 16, 2021 | 09:54 PM
Jero_b's Avatar
That's good to know. Thanks. I think I will use the all round performance stuff this time and then try and source the ESP for the next oil change. The car doesn't get used that much. Less than 2,000km a year.
Old Aug 17, 2021 | 01:25 AM
5 Year Member
That should be fine short-term.
So for researching alternatives to Mobile 1. Look for a low "SAP" synthetic 0w 40. Dextros 2 designation is General Motors certification for the same "ESP"low SAP oil. type.
Old Aug 22, 2021 | 12:43 PM
Johnny Hotspur GT's Avatar
Administrator
Hello @Jero_b ,
Were you ever able to locate the label for the oil specs on your Bentayga ?
Like this sticker on my GT.
Like #12 for the many different markets.
https://www.scuderiacarparts.com/par...338/2091/36801
Johnny
Old Mar 13, 2022 | 05:09 AM
Jero_b's Avatar
Bentley confirmed the car takes 0W-40. Thanks for all your help
Ryan lafferty
Bentley
10
May 3, 2023 12:03 PM
boudreaup
Jan 12, 2022 06:00 PM
gliozzi
Bentley
16
May 24, 2020 05:52 AM
nnorth
Bentley
Mar 6, 2017 01:19 PM
sirgolfalot
Apr 9, 2010 09:39 PM
