BGT 2005 Ignition wiring in or to bring back ignition signal on pin1 of OBD socket
Old 02-15-2022, 07:37 AM
kilog's Avatar
kilog is an unknown quantity at this point
Hello,
Now I have replaced the suspension compressor with a brand new one.
I can undertake level control basic settings fairly well:
The pression inside the compressor is >10bars.
I am able to rise rear wheels that move very well
the front wheels can move but just a bit.
The Suspension Level Control Calibration with configuration of the height can not executed with success.
Before the calibration all the requierements (engine running idle, gearbox to park, doors, bonnet, trunk locked) are checked. After getting inside the Control Module when I validate the height of the first wheel I can not type in the second value I have this error.
i tried it more than 5 times with the same result.
XXXXX
#34 error while calibrating
#34 after error while calibrating the basic settings also displays error
I also noticed that from time to time I cannot access to Level Control Module #34
#34 not accessible
#34 now accessible after ign off 5mn and on
As whell as I cannot access to #04 Steering Angle Control Module and #44 Steering Assist Control Module (both in direct access and during the diagnostic session).
Permanently inaccessible default on #04 Steering Angle
Permanently inaccessible default on #44 Steering Assist the steering wheel is very hard to turn
Please find attached the Auto-Scan listing using VCDS
Based on those details how can I set the ride height of the car
Best regards
Darryn
Bentley
15
08-07-2021 08:02 PM
Benebasil
Bentley
16
04-12-2021 03:41 PM
Simonbaz
Bentley
11-12-2020 11:12 AM
Joe Boccia
Bentley
11-25-2016 11:41 PM
Quick Reply: BGT 2005 Ignition wiring in or to bring back ignition signal on pin1 of OBD socket
