Shop manual
Old Oct 5, 2022 | 08:06 AM
355spider's Avatar
355spider is infamous around these parts
Shop manual
Does anyone have a digital Shop manual I can have a copy of? I bought one online but can't for the life of me get it to work.
Old Oct 6, 2022 | 07:57 AM
Johnny Hotspur GT's Avatar
Administrator
Hello @355spider ,
Which manual did you buy, and did you try setting the date of the computer back to the date required for the certain software you purchased ?
Johnny
Old Oct 11, 2022 | 08:02 AM
Mars911's Avatar
Mars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond repute
The disc I have requires me to set the date prior to January 2012 when I open my manual.
Old Oct 11, 2022 | 04:15 PM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
As far as I knew there was no easy way to get a shop manual for Bentley..
Could any of you fine lads tip me off as to where I could procure one? Thanks.
Old Oct 11, 2022 | 04:25 PM
Mars911's Avatar
Randy
I recommend you get the IETIS from Flying Spares. It has the manual and a part listing of all parts. It's the best information I have found for looking up parts and how to work on the car since it has the official dealer repair guide in it. It's very detailed. Here is a link to the DVD or USB stick. Many times the mechanical parts for the Bentley can be matched up to a VW Phaeton, but not the actual body parts which are Bentley. They can also cross to some of the Audi and others. As you read through this forum, you will get a wealth of information.. Lots of the engine and suspension can also be crossed to the Phaeton. Here is a link to the guide..
https://www.flyingspares.com/parts-workshop-manual-cd-cgt-gtc-flying-spur-models-wt01000-dvd.html
https://www.flyingspares.com/parts-w...01000-usb.html
https://www.flyingspares.com/shop/bentley-continental-gt-gtc-cgt-flying-spur-speed/gt-gtc-flying-spur-handbooks-service-record-books.html
Old Oct 12, 2022 | 02:33 PM
Randy V's Avatar
5 Year Member
Much thanks!
https://www.flyingspares.com/shop/be...ord-books.html
The DVD contains the Service Manual. What is is the Continuation Service Manual?
I'm interested in getting a hard copy of the Service Manual.
Originally Posted by Mars911
Randy
Old Oct 13, 2022 | 12:34 PM
tteplitzmd's Avatar
5 Year Member
tteplitzmd is infamous around these parts
How about those of us with a generation 2 (2013 and up)?
Old Oct 14, 2022 | 10:03 AM
EJag66's Avatar
5 Year Member
EJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud of
Hear, hear
Old Oct 16, 2022 | 09:26 AM
Mars911's Avatar
I am not an expert on this part, but I believe that the later cars are not covered since Bentley went to a different system which is why when you use the disc, you have to put a date in prior to January 2012 for it to work. I would imagine, but this may not be accurate, that many things on the disc may be the same for later year cars, but that just some different components/numbers changing. I believe the platform has been rather stable/consistent and that many of the procedures would be the same for repairs.
In case you have not seen this yet, you may also want to get the Ross Tech VCDS. The Ross Tech VCDS to analyze and erase trouble codes. VCDS is not the same as the obd 2 port testers sold at car parts stores. Search for it in the forum, but since early Bentley Continentals have the same system as the VW Phaeton, you can use this for looking for faults and diagnosing your car if you state it is the Pheaton. I am not sure at what point the VCDS does not work with newer cars or if it still does. Here is a link to it.
https://www.ross-tech.com/vcds/tour/autoscan.php
FiiT
930 Turbo
Feb 24, 2009 09:07 PM
fastbydrmike
Nov 10, 2007 03:00 PM
