Clcing sound in dash, left side, when starting
Old Nov 13, 2022 | 11:32 AM
belton's Avatar
belton is infamous around these parts
Evey now and then, there is a clicking sound in dashboard, left side. It is th same sound as when you put the key in the slot and turn it right then left. After the click, the car starts normally. It has never not started, but noises like this worry me.
Any ideas?
Old Nov 13, 2022 | 06:54 PM
EJag66's Avatar
5 Year Member
EJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud of
Probably a silly question, but are you certain it isn't the steering wheel adjusting? Because of my presets I get that clicking noise every time I get in the car.
Old Nov 13, 2022 | 09:16 PM
belton's Avatar
Steering wheel doesn't move when I get in or out of the car. When I adjust, it is a nice smooth sound.
This noise is the same as the noise when you turn the key right to lef.
I worry about new noises.
Bob
Old Nov 18, 2022 | 06:45 PM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
I had that issue on the '09 that I recently replaced. It didn't happen all the time but enough so that I wondered about it too. Both the Bentley dealer and my Indie guy said not to worry about it. I did notice that it seemed to go away if I kept the car on the trickle charger and it happened far less often after the starter battery was replaced. Since turning the key to the left is used to give the starter battery a boost from the house battery, my guess is that when the starter battery is low maybe it does a self jump or just gets confused. No idea if that's accurate but when the starter battery has a full charge it wouldn't happen. How old is your starter battery? See if that helps and let us know!
Old Nov 18, 2022 | 08:49 PM
belton's Avatar
The batteries were replaced in 2019. That said, I have never heard the noise when I start the car in the garage, after it was on a trickle charger.
I will test the starter battery.
I will also check the battery voltage after it has been on the trickle charger for a while, and again after I have driven the car for a while. If it is lower after driving, that might point to the problem.
Thanks for the advice.
Bob
Old Nov 18, 2022 | 09:45 PM
BruceR's Avatar
5 Year Member
Hope that puts you onto something. Here in Florida a 3 year old battery is ripe for replacement. In MI maybe the cooler weather lets them last longer but I wouldn't be surprised if it's near time for a new one. Even if the voltage looks OK use a load tester to get the whole picture.
Old Nov 19, 2022 | 05:27 AM
Samhain's Avatar
Samhain is infamous around these parts
Could it be the solenoid in the trunk that bridges the batteries together for starting when the house battery is low? The sound doesn't come from the steering wheel but could be heard as a clunk or click in the cabin.
Old Nov 19, 2022 | 08:57 AM
BruceR's Avatar
5 Year Member
If belton and I experienced the same thing it's definitely coming from the key operated ignition switch but very well could be operating that solenoid. The sound is what you'd expect if a contactor relay were opened and closed. If I remember correctly it's three clicks but very rapid so I may not have counted right.
Old Nov 19, 2022 | 09:19 AM
MAUMAU's Avatar
MAUMAU is infamous around these parts
This is totally out in left field and I know zero about repairing these beauties, but I watched this video yesterday.
Could the clicking sound be associated with the steering wheel lock/unlock solenoid?
Low voltage or a dying solenoid could cause the clicking.
Steering wheel locking solenoid starts just after the 13:00 mark.
https://m.youtube.com/watch?v=2dc2jLtQ8YI
Old Nov 20, 2022 | 09:29 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Any ideas?
Hello,
Possibly the stepper motor for the fresh air/recirculation flap hunting. Mine does this on start up and stops.
Try uploading an audio, might help further?
E
lovingit
Jan 8, 2019 11:22 PM
RichardC
Oct 2, 2014 07:29 PM
gammaman
Cayenne 955/957
16
Dec 11, 2010 01:47 PM
yalmutawa
Cayenne 955/957
Feb 28, 2010 11:19 AM
