Leaking valve covers on my 2013 GTC with only 18,000 miles
Old Jan 23, 2025 | 05:55 AM
  #46
lkevans's Avatar
lkevans
BWings, I have a 2010 GTC Speed with a P0017 code, and I plan to replace the VVT. I assume I have to remove the valve cover to access it. If so, I need to replace all the involved gaskets and seals plus probably plugs on only that side while I'm there. Do you suggest a particular manufacturer seal kit and plugs for this, other than Bently? And, am I right that the VVT has a different plug connection so that it doesn't interchange with VW and Audi? Thanks. LKe
Old Jan 21, 2026 | 02:50 PM
  #47
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
Hey guys, my cars smells like burning rubber after its driven. I originally thought it was the serpentine belt, but my indy took a look and determined that there's a leak from the valve cover and its hitting the exhaust - producing the smell. There's no oil on the garage floor. @BWings , @Johnny Hotspur GT , did you guys have a burning rubber smell? I'm trying to decide if i should get on the repair sooner - or later?
Old Jan 22, 2026 | 01:13 PM
  #48
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
Both my '09 & '16 W12's had the same kind of seepage @ around 20K miles & my indy told me to leave it alone and just watch it. Cars ran fine for as long as I had them. No leaks on my '20 V8 @11K miles - yet!
Old Jan 22, 2026 | 01:21 PM
  #49
ttpopo's Avatar
did you have a burning oil smell?
Old Jan 22, 2026 | 02:23 PM
  #50
BruceR's Avatar
5 Year Member
No smell ever but my sense of smell is almost nonexistent. But my wife never mentioned it.
AEsco48
Aug 27, 2014 07:20 AM
kent996
Feb 18, 2014 01:49 PM
cremaley
Mar 26, 2013 05:47 PM
joekimdds
May 27, 2006 11:08 PM
