Upper coolant hose question
Old Mar 2, 2023 | 12:51 PM
Shaqovic's Avatar
5 Year Member
Shaqovic is infamous around these parts
Hello Members,
I just came to check on my GT 05 after being parked for over than 2 months no start, and found both front side in the ground which means suspension leak in front, rear is still high, also the front wheels looks bent from over weight on them which I hope no replacement needed after putting the car up again don’t know how yet
started the car and noticed upper coolant hose leaks which connected to thermostat, would it need a new o ring or a complete hose, or maybe RTV should seal it.
Any help appreciated 😊
Old Mar 3, 2023 | 02:15 PM
Shaqovic's Avatar
5 Year Member
Any help appreciated from members and admins
Old Mar 3, 2023 | 02:37 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Originally Posted by Shaqovic
Hello Members, I just came to check on my GT 05 after being parked for over than 2 months no start, and found both front side in the ground which means suspension leak in front, rear is still high, also the front wheels looks bent from over weight on them which I hope no replacement needed after putting the car up again don’t know how yetstarted the car and noticed upper coolant hose leaks which connected to thermostat, would it need a new o ring or a complete hose, or maybe RTV should seal it. Any help appreciated 😊
Please post a couple of pictures related to the leak. Indeed the hose attachment points have internal "o" rings.... no RTV sealant please👍...Anyway pictures would help to ensure we are [all] on the same page.
Old Mar 3, 2023 | 02:41 PM
Shaqovic's Avatar
5 Year Member
is this o ring replaceable or not ?
Old Mar 3, 2023 | 02:54 PM
5 Year Member
Yes, remove the fitting and pull the "o" ring and size it up. I don't know the size. McMaster Carr is the best source for quality replacements. Use their size calculator and select the proper product type for this application.. ​​​​​​​
Old Mar 3, 2023 | 04:02 PM
Shaqovic's Avatar
5 Year Member
Is the o ring placed on the thermostat or the coolant hose ?
I remember replacing the thermostat for one of my previous GT which was pain in the A$$ but don’t remember there was an o ring
Old Mar 3, 2023 | 04:10 PM
5 Year Member
Is the o ring placed on the thermostat or the coolant hose ?I remember replacing the thermostat for one of my previous GT which was pain in the A$$ but don’t remember there was an o ring
Inside the coolant hose. When installing use, for example dielectric silicone grease on the "o" ring. The refit is tight and getting it fully seated before installing the metal lock ring is critical.
Old Mar 3, 2023 | 04:15 PM
Shaqovic's Avatar
5 Year Member
Thanks for the info
I will try to pul it, if not worked then I guess RTV should be a fix, unless there’s an explanation for not using it there 😊
Old Mar 3, 2023 | 04:21 PM
5 Year Member
Thanks for the infoI will try to pul it, if not worked then I guess RTV should be a fix, unless there’s an explanation for not using it there 😊
High heat, glycol coolant and pressure RTV is iffy. Bentley went the extra yard with "o" rings and not clamps as well...just saying. 😏
Old Mar 3, 2023 | 04:24 PM
Shaqovic's Avatar
5 Year Member
If I’m following you then you mean RTV will melt and cause damages !
cuz Bentley already did a great job and make us busy repairing their ****y cars every week 😂
Old Mar 4, 2023 | 06:43 AM
2007Conti's Avatar
2007Conti is infamous around these parts
As far as bent wheels, I think you'll be fine. Never heard of a wheel being bent because of a suspension drop.
I'm guessing you don't have a battery tender, right?
Old Mar 6, 2023 | 09:21 AM
Shaqovic's Avatar
5 Year Member
I have a battery tender, it’s not an issue with battery since I unplug both negative terminals for long park garage with trunk latch closed while opening the boot, I applied RTV, leakage stopped finally and could feel water through the upper hose but temperature gauge is still goes high pass 90c
any ideas ?
evdean
Tech / How To
Aug 4, 2018 08:23 AM
ssj4
Apr 12, 2014 12:12 PM
bmwtmx
Dec 30, 2013 09:09 AM
TimAZ
Oct 5, 2013 09:41 PM
JSmith5690
Jan 19, 2008 01:01 AM
