Hello @Shaqovic ,
As to the extra connection plug in the driver's side cowl area, I ran into this during my rebuild, and I swear I posted about it, but I can not find it, but, here is what it is, see the bracket with the two threaded bolt holes, that bracket and the extra plug are for a hot climate option, this option has an extra coolant circulation pump mounted to this bracket and plug.
My issue was that both plugs are exactly the same, therefore I plugged the wrong one into the driver's front suspension strut, which inturn give me a suspension fault, I was almost ready to tear into my wiring harness, but a light bulb went on in my head, I swapped the plug, and all was good.
As to the 3D0915181C, I have a brand new one, it was outrageously priced, I was planning on saving it for future needs, but make me a pm offer.
Johnny
.Your Picture.
My Vehicle.
Hello @Shaqovic ,
Johnny
.Your Picture.
My Vehicle.
so the plug with blue and yellow lines are for hot climate pump ? Yet I need to find its male connector.
i can’t make an offer for a brand new one, on eBay used modules starts from $50, maybe you have 3D0915181D as some guys replaced it with older D version and it worked %100.
Hello @Shaqovic ,
Did you ever take the pictures of the passenger side turbo with the plastic bag out of the way to show the tubing pulled out of the port ?
Trying to help a fellow member.
Sorry I missed your last post, to answer the question, the blue and yellow wired plug is for the driver's side strut, but you did away with them, so, I assume that you plugged resistors into all strut plug/connectors to clear the suspension fault on the dash, ?
Johnny
