Are the front control arms of the Phaeton and Bentley the same?
Old Feb 6, 2026 | 09:11 AM
Bentley_Germany's Avatar
5 Year Member
Bentley_Germany is infamous around these parts
Hi everyone,
I was at the vehicle inspection in germany today (MOT test in UK). During the inspection, it was found that the seat belt does not retract properly on its own, and that there is excessive play in the front axle, meaning the front control arms most likely need to be replaced.
Given the age and mileage of the vehicle, I was considering ordering a complete front control arm kit, as I would like to carry out the wheel alignment only once.
Most of the Volkswagen Phaeton suspension components should be largely identical, but I’m not entirely sure if this is actually the case. Some of the parts have part numbers starting with “3W”, which makes me a bit uncertain.
Bentley: https://www.flyingspares.com/suspension-arm-kit-8-arms-upper-lower-steel-lower-straight-arm-2004-2012-approx-steelarmcompkit.html]SUSPENSION ARM KIT (8 arms upper & lower - STEEL lower straight arm 2004-2012 APPROX) | Flying Spares
Phaeton: https://www.ebay.de/itm/254159565163?_skw=Querlenker+Vorne+Phaeton&itmmeta =01KGSV563RG3ZTHZF8EZNJSXN0&hash=item3b2d17316b:g: yboAAeSw159n2A2E&itmprp=enc%3AAQALAAAA4GfYFPkwiKCW 4ZNSs2u11xDddsq69UfWniMovdmHgeTfsTsvEvuPUXcuoP1y2k rsYPE5tBt3fQ5lHnHxgXgg1X5j%2F9Wy3HH5o52p%2FSuQQyB3 LVvrez3bPsMJvcoN2cVLEkR06BWHhZHd5p%2B%2B8oB7%2Bg3R a2g65GgeLtzER35q3urZNBYqEzD6IkTTakWSmpNSpDQ5KLGyyR TLbF0Hb%2BAqHPytqgmsJlhaYsRJHBavF%2BFVz0usedE5ElW9 l4%2F06kQOJnis0N4EOf8sBI1DQRHOE6GWdQAuF5%2FqnzC%2B BhiEgtKd%7Ctkp%3ABk9SR5TilLuGZw]LEMFÖRDER Querlenker Vorne Unten Oben Satz für PHAETON 4MOTION VW | eBay.de
Has anyone here ever ordered a complete control arm set and can confirm whether the parts are a direct 1:1 fit?
Additionally, what would be the correct way to fix the issue with the seat belt retractor, as the belt no longer retracts smoothly by itself?
Many thanks in advance for your help.
Old Feb 6, 2026 | 07:30 PM
bmwfan996rookie's Avatar
bmwfan996rookie is infamous around these parts
lookup a place called TOPEURO parts in Hallandale, FLORIDA, USA
They sell aftermarket replacement suspension and maintenance parts for Bentley Aston Benz.......
Ive been going there for years, yes they ship also. Fraction of dealer prices
Good luck
KJ
Old Feb 7, 2026 | 06:06 AM
CUE99T's Avatar
CUE99T
Good luck
KJ
Looks like you need to be a wholesaler for them
https://topeuroparts.com/
Is that the company?
Old Feb 7, 2026 | 12:24 PM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
The problem is usually only the bushings (bushes) that are pressed into the control arms.
Rather than spending thousands on complete control arms I purchased the control arm bushing kit on Flying spares for around $450 US.
The shop was able to replace just the bushes for 2 hours labour. Add additional charge for 4-wheel alignment. What one shop quoted me at $5000, the other dis for only $1200, plus the cost of the bushing kit that I bought directly from Flying Spares.
Here's my recent discussion here ;
https://www.6speedonline.com/forums/...trol-arms.html
My car now drives like a brand new vehicle - the improvement in handling is remarkable.
Good luck.
bobbally
Bentley
Jul 14, 2023 09:54 AM
Jurgeenh Borbon
Bentley
Sep 24, 2022 03:34 PM
Randy V
Bentley
Aug 3, 2021 02:58 PM
gtjay
Bentley
14
Apr 21, 2021 09:25 AM
lilo1980
Bentley
18
Sep 29, 2013 03:38 AM
